Results 1 to 10 of 11
Thread: Parking Sensors on Vectra Estate
    Wiltshire
    Default Parking Sensors on Vectra Estate
    Hi all.
    Can anyone post me pictures of aftermarket parking sensore fitted to a Vectra estate? I can only find pictures of hatchback models.
    I am dubious about drilling the bumber in case they are wrong. I was gonna put the outer two to the outside edge of the reflecters in the black trim below the bumper but because of the angle of this I was worried that they will pick up things I am parking next to (i.e. the fence I park alongside on my drive with about 6" gap between car and fence)
    The sensors I have are these http://cgi.ebay.co.uk/REAR-CAR-PARKI...QQcmdZViewItem
    I also apologise for the long hyperlink.
    Thanks.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Wiltshire
    Thanks for the reply John, fitted them and tested them. They work well so will probably by a set for the van now aswell !!!
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Does this kit set off the Light Bulb Warnings??
    What wires did you connect it to?
    I have still to install my Meta Targa 2 (parking sensors mounted on number plate holder) and I might get one of these kits instead, might be easier to fit, as the Targa 2 requires the inside of the tailgate to be stripped out.
    Sunny Dartmoor
    None of the parking sensor kits sets off the bulb waring mate,i have fitted these ones to mine and have ordered some for my work van also,great fit and very easy mod to do for less than £30..........
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=012
    Regular Member wardy's Avatar
    Chichester
    Quote Originally Posted by Marky View Post
    Look here:
    http://www.vectra-c.com/forum/showth...ersing+sensors
    and
    If you're still stuck, pm me
    And no, works fine with the bulb warning system
    And that is my Vec Estate in John35s link
    Jun 2006
    North West
    Thanks for that. So what was the bypass relay for?? (My memory has gone :-)
    Few more questions if I may.
    1) Did you have to take the plastic trim off the bottom of the bumper to drill the holes? Was it already marked up?
    2) The rubber bung that you passed the wire through where inside the car did they appear? Was it under the storage compartment at the end of the spare wheel bay?
    3) How did you connect the wire to the connector in the fuse box? Did you scotch lock it to any existing wires?
    Thanks, Mark
    Wiltshire
    Marky,
    Answer to 1
    No, I left it on, I got a centre line by running a compas in the groove between the bumper and trim. I cable tied the cables behind to the clips that hold the bumber and trim together and then loomed them with black tape and brought them in through the said grommit in question 2.
    Answer to 2
    Yes it is.
    Answer to 3
    Scotch locked to the black wire (top right) and to an earth wire (any brown wire)
    Doesn't affect my bulb warning (don't know if I even have one, mines a 55 plate facelift Design)
    As glenboy said, gonna get some for my van too, there a good piece of kit!
    Hope this helps.
    Chichester
    didn't remove it, but it wasn't marked (that I could see) Just stick your head under & check that you are not going to hit any of the clips that hold it on.
    Yes, need to remove the inner trim from inside the boot to gain access.
    Scotch lock to the live feed as in the photos in previous link. Earth is available in the same storage compartment that the cables come in through so no need to drill the body work.
    Thanks, Mark
    Best of luck.
    Jun 2006
    North West
    saulty, wardy: Cheers guys for the helpful info.
    Did you use a normal electric hand drill for the holes?
    I think a trip to ebay is required....
  1. Estate Parking Sensors.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2017, 01:27
  2. estate rear parking sensors
    By Ryanlfc in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2012, 20:34
  3. Estate Parking Sensors
    By jbegbie in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2007, 20:14
  4. Parking Sensors again on an Elite Estate
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 10:35
vectra c parking sensors
reversing sensors for vauxhall vectra estate
vectra estate parking sensors
rear parking sensors for vauxhall vectra estate 2005
vectra c parking sensor wiring
vectra c parking sensors connect to android headunit
connecting parkng sensor on vectrs estete
realy for vectra c parking sesr
parking sensor for vauxhall vectra bay online
car reversing sensor kit for vauxhall vectra estate
vectra estate parking sensor wiring
