Thread: GSi - going, going, BOING!!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default GSi - going, going, BOING!!
    Got into the car tonight and there was an almighty boing sound. I could only think the worst and suspected one of the springs.
    Had a quick check and all seems OK. Drove over a few speed bumps and still all felt OK. Handling and steering at high and low speeds also seems the same (and the brakes still work).
    I know it's hard to diagnose without a sound (this thread is useless without noise ) but anyone had anything similar?
    Am I worrying about nothing
    Regular Member Ian's Avatar
    York
    could it of been the spring popping back into its seat? My asta does a fair bit. Start it up on the drive, reverse back and then set off and I get a boing klunk from the drivers front. I had it looked at by two garages I trust and they cant find anything wrong. One of them theorised at the above (spring popping into the seat)
    sounds like it needs the spring seat mod..
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    That's what's worrying me - it's got the mod. I've also looked at all the linkages, drop arms etc., and all seems fine.
    the mods do bind after a while.. i seat mine in grease to help them work...
    try spraying lots of wd40 or spray grease into the tail well in the spring pan..
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Will do Mark but I'll wait until daylight in case I spray the discs
    Full Member
    Mar 2007
    Finland
    Could it be possible that the strut top bearing is causing this issue? I mean that if the bearing is stuck/harsh, would it then prevent the sping from turning smoothly and cause this popping in the pan?
    it could be that, but Vectra-c is well known for the springs binding in the pans unfortunatly....
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    What spring seat mod??????
  1. Seatbelt boing
    By bigmac in forum Insignia car chat
    Last Post: 9th March 2011, 15:33
  2. Boing Boing noise from suspension
    By greg377 in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2010, 18:40
  3. Boing-boing !
    By FIL 4822 in forum General Chat
    Last Post: 5th May 2008, 14:34
