Thread: Loud power steering.
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    Default Loud power steering.
    I have noticed a noise coming from the power steering seem to be a whining type of noise when im turning the wheel it is more noticable when the tc has been turned off.
    Any others had this problem?
    Mileage : 000
    I don,t know if it would help, but if there was air in the system if you turn the wheels from lock to lock it should get the air out, or at least it used to on older cars, might be worth a try.
    Regular Member mat osborn's Avatar
    Jan 2008
    leicester
    try checking your power steering fluid level if it is low then more than likely a leak somewhere
    Jun 2007
    driffield
    Quote Originally Posted by ed taylor View Post
    Thanks i will give that a try in the morning,the fluid level should be ok as its not long since i checked it and i have not seen any puddles under the car.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
