Thread: Sidelight bulbs change.. how 2??...
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Sidelight bulbs change.. how 2??...
    cant for the life of me find the how 2 , to fit the sidelights.. need the pics 2 see which part of the light needs to come off...and which bits to twist/untwist etc... help please..
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    got no pictures mate but i took the air box out twist the big black caps on the back of the lights .the side lights are a right pain in the a$$ try and use a pair of long nose pliers
    Darlington
    If its a face lift the side lights pull straight out. No need to take the air box off.
    You will need to take the rear plastic light cover off. This is a short turn anticlockwise.
    I did both lights in 10 minutes total.
    Not sure whats involved if its a pre-facelift.
    [Ex]Admin Duncan's Avatar
    Sidelights on yours Dwabo (pre-face) are behind the oval shaped plastic covers that click into the back of the light assembly. Bulb just pulls out, no need to twist or anything. You can do it all without having to remove the airbox - as long as you don't have hands the size of plates! lol
    never mind..i was pulling at the wrong bit!!
    and yep..i have fat fingers too and sttill managed without the airbox off.. i knew it was behind the covers but ended up tryin to unclip the wrong section.. all sorted now... cheers!!
    pics are here... mtec and bluevision sidelights...
    http://forum.vectra-c.com/showthread.php?t=37678&page=4
  1. LED sidelight bulbs/What do you use?
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2012, 19:39
  2. H.I.D's Fitted!!! :) Now how to change the sidelight bulbs?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2011, 21:51
  3. 501 sidelight bulbs
    By VectraElite 2.2DTi in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 23:21
  4. l.e.d sidelight bulbs
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 10:07
  5. M-tec 501 sidelight bulbs x2
    By bobby-tupper in forum Parts for sale
    Last Post: 31st May 2010, 14:24
