Thread: Help required regarding rear pads
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Default Help required regarding rear pads
    Hi guys looking for some advice, Rear pads needed replaced so went to the dealers to get a set. The parts guy asked what car they were for, I told him a vectra and away he went and came back with the pads.
    The problem I have is that now that I have taken the old pads off the new ones look different, well the inside one (i.e the one on the piston side of the caliper) I have taken a picture of both the old one had no spring clips on the back but spring on the edge. I just need to know if I can use the pads I've been given or if they are the wrong ones.
    Many thanks for any replies.
    ps car is an 07 plate sri cdti
    [Ex]Admin Duncan's Avatar
    Don't worry. The design of them changed and the ant-rattle spring design was changed somewhat - as you can see.
    All you have to do is make sure that those bits slide over/behind the end of the piston - if you see what I mean - so that the pad is held in place.
    If you want to post up the part number of what you were given, I can double check that they are definitely the right ones.
    Jan 2008
    Paisley
    Thanks Duncan, for the quick reply just wanted someone to confirm this for me cheers
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just changed mine not long ago mate and the spring clips were different as D says.
  1. new brake pads required!
    By VeccyMike in forum Suspension, Wheels & Brakes
    Last Post: 14th August 2012, 15:57
  2. help with rear caliper required.....
    By iainm9438 in forum Suspension, Wheels & Brakes
    Last Post: 9th April 2012, 20:59
  3. new pads and discs required
    By gordy07 in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2011, 13:15
  4. which rear pads for a 3.2?
    By andyxedos in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 19:05
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
