Results 1 to 4 of 4
Thread: Juddering and intermittent spanner light
    Sep 2007
    Durham
    Default Juddering and intermittent spanner light
    Just driving down A1 this afternoon and car started to judder. No warning lights so continued to see if it improved. Power under acceleration seemed poorer than usual. Anyway, came off at my junction and noticed just after going round roundabout, the spanner (car with spanner) light came on briefly then went out. Popped on once more when I was almost home but again went out.
    Any ideas? Had no problems with it up until now
    Car is 2004 1.9CDTi (150)
    Technical directors office
    could well be the dreaded swirl valve again....
    Code reader time to see what the codes are behind the fault...
    Administrator plasma's Avatar
    Mar 2006
    On the Forum
    572 Post(s)
    Engine : 150
    Year : 05
    Mileage : 74000
    Juddering during acceleration through all the rev range points to injector number 3's wiring harness shot, (theres a mod out to replace this), pure performance from idle to 2000 rpm could be swirl valve/EGR valve.
    Apr 2008
    manchester
    Default injector no. 3
    Would you know what the injector no.3 wiring modification is and what needs to be done to solve the problem? Is it a job for a VX stealer only?
    Many Thanks,
    Ched
  1. Intermittent spanner light 2.0 t
    By roverjay in forum Engine & Drivetrain
    Last Post: 13th January 2016, 08:47
  2. intermittent spanner light
    By dervb in forum North West (RO - bonehead, ARO Woody
    Last Post: 26th June 2012, 02:01
  3. intermittent spanner light
    By dervb in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 23:10
  4. Intermittent spanner light
    By ScubySteve in forum Engine & Drivetrain
    Last Post: 20th February 2009, 17:47
  5. Help intermittent spanner light
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 21:20
