Results 1 to 3 of 3
Thread: Just had first service
    Regular Member videodoctor's Avatar
    Blackpool
    Default Just had first service
    My 1.8vvt veccy went into the main dealers for its first service this week.
    I pointed out a few things that needed looking at and they have fixed them all.
    First was,since having a new modified clutch at 2800 miles ,the brake pedal was never as firm as it was when it was new.Also i still got an intermittent clutch judder when setting off in first even though it was changed.
    The garage bled all the brake system and now the brakes are solid again.Also the clutch action is now smoother with no juddering at all.I believe this is because the brake and clutch cylinders are the same and bleeding the brakes can affect the clutch(might be wrong,but hey i'm no mechanic)
    I also complained about the accelerator lagg which caused a jerk between 1st and second.
    They have now updated the ecu and when you change gear the revs stay up for longer so that as you change gear the revs are still high for when you let out the clutch and thus eliminating the jerk.
    So overall the car now drives much nicer and smoother than it did pre service so i am well pleased with my local dealer(Moorland Motors of Blackpool).
    Regular Member dezzie's Avatar
    May 2006
    blackpool
    i bought my vec from moorland when they were on Dover road before they moved to whitehills,and also found them to give good service. must be one of the better dealers
    Regular Member DarrenLee's Avatar
    Shipley, West Yorkshire
    Good result - seems like a decent garage
  1. Replies: 341
    Last Post: 20th April 2016, 06:29
  2. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  3. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
