Thread: Passenger footwell flooded???
    Regular Member danlat1415's Avatar
    Lancashire
    Default Passenger footwell flooded???
    Hi guys, not been on here for a while, but I'm having a problem with the Vectra.
    For the past few days, the passenger footwell has been like a lake. It's been raining a fair bit, but the water seems to be getting in somewhere.
    I don't think it's the door because it shuts as normal, and I can't see any splits.
    I'm sure I noticed a while ago that someone else had this problem?
    I'm just wondering is it a common problem and what is usually the cause??
    Also, I don't know if this is related, but the FAN on the dask board only works when you turn it to 4. 1, 2, and 3 are off, and 4 comes on fast as it should. I can hear it click somewhere near the glove box when I turn it to 4 and it comes on, then it clicks off when I put it to any other number.
    Dan
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Looks like water ingress caused by blockage of the drain underneath the pollen filter. Lift bonnet, lift up/open flap on your right hand side under the windscreen (where the rubber has 2 cuts) and look in front of pollen filter. There is a drain for the water to run off, which may be blocked with leaves and/or $hite. Easy to clear by pushing your hand down through the rubber hose inside. Water ingress could also have compromised your heating/ventilation controls by shorting out the relay. It pays to check the drain regularly, and also to check that the grommet underneath hasn't been rotted, thereby increasing water ingress.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by danlat1415 View Post
    Dan
    Try this for your heater blower
    http://forum.vectra-c.com/showthread...light=resistor
    HTH
    3.2 v6 Signum and loving it
    Regular Member D-S-Dave's Avatar
    Jun 2006
    Home init
    Had the water in the foot well problem in Febuary. Carpets were damp for weeks. Problem was the pollen drain hole. Ended up taking all the door frame trim off and lifting the carpet to air and dry it.
  1. Wet passenger footwell
    By aaruck in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 11:13
  2. wet passenger footwell
    By n8sby in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 20:40
  3. Passenger footwell wet in the Vec-B, HELP!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 22:22
  4. rear footwell flooded.
    By tollitt2008 in forum Bodywork & Interior
    Last Post: 26th October 2008, 15:48
  5. wet passenger footwell
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2007, 23:42
