Results 1 to 3 of 3
Thread: Another lowering question !
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Default Another lowering question !
    If i change the springs on the standard SRI suspension by lowering it -30mm, will they fit correctly and not be loose, rattle & clonk or will i need shorter shocks to avoid this ?
    I know fitting a full suspension kit is the best way to do it, but i don't want to go to that expense at this moment in time, just want to "Test the water" so to speak then maybe get the shocks later if i'm happy with the feel.
    Fil, if you want to go -30 from SRi level then you'll need something like Pi -45mm springs as the SRi already sits at -15 to the 'standard' ride height.. if you fit those -45's you can get away with the standard SRi dampers as they are already shorter in their stroke.. -30's ( -15mm from standard) work well with the standard SRi shocks....
    If you buy quality springs ( like eibach or Pi) you won't get fit or rattle issues, can't comment on the cheaper brands..
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    Ok, thanks Mark
  1. Lowering Question?
    By Del101 in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2013, 18:28
  2. camber question after lowering
    By Mads in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2011, 13:24
  3. lowering question
    By davidmcd2002 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 15:32
  4. lowering question
    By MSharkey in forum Styling
    Last Post: 15th October 2009, 11:22
  5. Lowering Question
    By Genterz in forum Handling & Braking
    Last Post: 18th September 2008, 13:45
