Results 1 to 10 of 15
Thread: reg plate bulbs
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default reg plate bulbs
    Hi
    Can anyone advise if there is a 'warning' for reg plate bulbs not working? Car appeared fine but the Dealer told me today that reg plate bulbs are out? I hadn't noticed (obviously).could be something easy but just wanted to make sure it hasn't been 'introduced' today while in the Dealers
    John
    Sunny Dartmoor
    No,the only bulbs not on warning system.......
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    nope...mine blew totally and took me a while to find out...only by opening with keyfob and noticed something didnt look right!
    Apr 2006
    Inverclyde
    Is it common for both bulbs to go at exactly the same time?
    Are they easy to get out? Both of mine have 'gone' but not had a chance to look at replacing due to the lovely Scottish weather
    11 Post(s)
    Quote Originally Posted by johnmac View Post
    Dead easy. You'll need 2 12 volt/5 watt capless bulbs (501 type) and follow the info in the handbook - or click on the thumbnail below.
    May 2007
    Dartford
    with mine i didnt even need a screwdriver to pop out the plastic cover, then just pull out old bulb, push in new one. Remember to at least have the doors locked otherwise power will be going to these lights
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    bit of a kinda off subject but you seen the new bmw num plate bulds, hid style, proper white... now that is sexy, looking into some for my self
    Apr 2006
    Inverclyde
    On another note, is there a fuse for the number plate lights? If so, can anyone point me in the right direction.Can't see it listed in the handbook, but there are 3 fuse boxes 1 at the passenger side front (dash),1 in the engine and 1 in the boot.
    Apr 2006
    Inverclyde
    Apologies for continuing about this subject.......
    .......as far as I'm aware, my car was ok.Last week it went in to get a rear bumper repair done (plastic welded and sprayed).This was done in situ and the bumper was not disturbed (so I'm told).Got pulled by the trafs last week and informed that my reg plate bulbs were not working.Phoned the repairer and was told that the bumper was not removed and there was nothing disturbed.I read a post somewhere that there was a fuse (no 18) that did the number plate bulbs, but on looking, there is no No.18 in any of the fuse boxes (is that the problem ) The car is now due its MOT and that would fail it just now.Find it strange that both bulbs have failed at the same time so it would appear electrical and not simply a bulb fault.Any help appreciated
    mine blew (both) after my car was resprayed...obviously when they rebuilt the car and put everythin back 2gether
  1. LED Number plate bulbs
    By Beardy in forum Styling
    Last Post: 17th February 2013, 12:19
  2. Number plate bulbs
    By benwalters82 in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2013, 15:36
  3. Vec C 03 plate headlight bulbs
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2010, 21:49
  4. Number plate bulbs
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2010, 15:50
  5. SiggyNumber plate bulbs
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2009, 00:22
