Results 1 to 2 of 2
Thread: Fuel pump??
    Regular Member Robclowes's Avatar
    Oct 2007
    Crewe/Market Drayton
    Default Fuel pump??
    What are the symptoms of the dreaded fuel pump fault???
    I am suffering hesitation/missfire and fuel gauge fluctuations. I put £10 in on a quarter and it filled up!!!! Happy until it dropped back to a quarter within 10 miles!!!
    2006 Signum 3.0 V6 cdti euro4
    Booked in at dealers next Wednesday
    fuel pump fault is rough running and lack of pressure on the common rail lighting the EML..Fuel guage runs through the CIM module but the fuel gauge is also on the low pressure pump ( i think) so if there is a low pressure problem and a level problem i think that a fuel pressure check on the low pressure side would be a good place to start, as would a gauge test..
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Replies: 19
    Last Post: 30th May 2012, 15:53
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel Pump
    By seanyis in forum Engine & Drivetrain
    Last Post: 6th April 2009, 10:08
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
