Results 1 to 10 of 18
Thread: Cost of changing rear springs
    Berks
    Default Cost of changing rear springs
    I've been quoted £293 inclusive of VAT and fitting for 2 new rear springs....
    They said it would take about 1 1/2 hour each side.. Does that sound right?? A lot of money for a piece of spring.
    Cirencester
    if they had a ramp you could do each side in 10mins.
    Berks
    So they are liars in other words....
    If I buy them myself which ones would I need? I have a 04 1.9 CDTI 120 SXI.
    I've looked here:
    [url]http://www.lmfvauxhall.co.uk but could not find any rear spring coils.
    But the 1.9 CDTI is not listed as an option...
    Any ideas
    Berks
    I found a local garage near me who will do it for £180 all inclusive of parts and VAT....thats a bit more reasonable.
    The springs come at a cost of £100...aftermarket. I assume that should be ok?
    I also need the upper suspension mount bushes...but apparently you cant buy just the bushes and you need to buy the whole arm...at a price of £70 per side....outrageous since it's just a bit of plastic that is worn!!
    Regular Member EURO G's Avatar
    n ireland
    if your paying 100 for just rear springs mate why not just spend a few quid more and get a set of lowering springs alot better quality than original and will last longer,70 sound about right for the upper control arms
    member of the smoke patrol 230bhp+
    Berks
    I did look at LMF for springs but the lowering ones look quite expensive. Also, the £180 is really more than I can afford at the moment.... I've had some other unexpected (not car related) expenses so my wallet currently has moths coming out of it. I just need the absolute necessary for the time being.
    That's why I'm not doing the upper control arms just yet. The garage said it could wait.
    Regular Member eaglepva's Avatar
    Up North
    I replaced my rear siggy springs took 20mins each side its easy takes longer to undo the bolt under the arm than to change the springs.
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Quote Originally Posted by eaglepva View Post
    Is it easy to do the front springs? out of interest.
    Up North
    I didnt do the front springs as i had just 1 broken rear spring. I think the fronts are a lot harder and require spring clamps etc
  1. Cost of changing DMF and clutch and inlet manifold
    By Gregorezzi in forum Engine & Drivetrain
    Last Post: 30th March 2012, 12:14
  2. fitting springs cost
    By kirky2k4 in forum Styling
    Last Post: 4th February 2011, 13:58
  3. changing springs
    By kenny1zero in forum Handling & Braking
    Last Post: 30th June 2008, 02:12
  4. Changing rear siggy springs, is this the bolt to undo
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2008, 04:44
  5. changing springs
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2006, 22:45
how to change rear springs on vectra c
vectra c rear spring removal
vectra c rear springs
rear coil spring replacement cost
vectra c rear coil spring change price
new spring for vectra
vectra coil spring rear price
change front springs vectra c price
how much tobfita new suspension spring on vauxhall vectra
how easy change front spring vectra c
vectra rear.suspension cost
vectra broken spring
vectra c front spring replacement cost
vectra c rear coil spring replacement
suspension spring replacement cost
vauxhall insignia rear coil cost
vectra c bias spring
replacing the rear coil spring on a 2007 vauxhall vectra
signum rear springs
vectra rear spring replacement
vauxhall vectra rear spring replacement
cost to replace front suspension spring vauxhall vectra c
how often should you change rear springs on insignia
cost of fixing suspension on vauxhall signum
how to replace rear springs on vectra c
