Thread: Some inside info from VX about handbrakes and springs
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Default Some inside info from VX about handbrakes and springs
    I bumped into a friend who works for VX customer service last night. We were chatting for a while, and I amanged to glean some information about the handbrake and spring issues we're seeing. I don't mention any names or anything, as I don't want to compromise his position -having said that, I don't think he gave any secrets away. Some of this info may have already been posted, and I apologize for any repeats!
    The handbrake issue:
    The handbrake ratchet depends on two teeth on the pawl engaging with the handbrake ratchet. The problem occurs when the lever comes to a halt with the pawl teeth resting on the ratchet teeth, rather than in the "valley". If something makes the lever drop, instead of just going into the next "valley", it can drop right down. If you've got bad habits, like me, and just pull the lever up without pressing the button, you'll almost certainly not get the problem. If you press the button while pulling the handbrake up, you can get the problem. The fix involves adding an extra spring into the mechanism, which increases the ratchet spring from about 7 newtons to around 21. This will make the button harder to push, but should get rid of the problem. Letters will start going out at the beginning of April, at the rate of 10,000 per month.
    Springs:
    This one is less cut and dried. It only seems to happen on cars that are a couple or years old, or have quite high mileage. It also seems to be worse in Northern European countries than Southern Europe, which leads to the suggestion that it's related to corrosion. Current theories revolve around road dirt build up on the springs, leading to small areas of severe corrosion, leading to breaks. New Saab 9-3's (which also get the problem) are now being fitted with shrouds on the front springs, as will the Insignia.
    That's it!
    Phil
    Nice to see something is happening, I take it you mean suspension springs and not hand brake springs in the secone part of your post?
    Luton, Beds
    Yep!
    Phil
    Jan 2008
    No idea....
    Finally...! Thanks for that.
    I always press the button to apply the handbrake as I had it drummed into me the ratchet noise was bad (I hate even hearing the ratchet noise now, makes me cringe, so he did his job well!).
    Had no roll aways yet but I do try and leave it in gear, now and again ill go back to the car and see I didnt and swear at myself lol
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    I press the button but let it click a couple of times towards the top..
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    great imfo Phil,,,,,,,,,,,,,,sooooooooooo 10.000 amonth ,how long b4 we get one then lol just how many veccies are there out there
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    Somebody said there were around 250,000 Vectra C's around, so if thats true they will all be sorted in the next two years or so, reassuring eh? lol
    Sunny Dartmoor
    Great news,will get my letter the day after i sell it then.......
  1. apex springs some info
    By davedave in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2012, 20:15
  2. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. Not just vectra handbrakes then...
    By TheWildHaggis in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2008, 21:57
  5. Failing Handbrakes ...(Recalls)
    By The-Bandit in forum General Chat
    Last Post: 3rd February 2008, 22:13
