Thread: Brakes
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Brakes
    Changed the front brakes last weekend(discs n pads to mintex). Job was a slight hassel, but mainly down to the lack of tools and the faff about to get them when the car was off the road.
    Im impressed enuff with the diff, even though the 'old' lockheed pads still had approx 7mm material left, that im considering doing the rears.
    Visually theres still approx 5mm plus left of material,discs are lipped at both the top and bottom edge.
    Price wise for the mintex setup im looking at approx £60.00(plus the rewind tool)...
    Do you think its worth the expense/effort??
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    there ar rewind tools on ebay for the rear calipers and if the discs are lipped then it best to change then m8, safty first
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thanks glynn. Im able to get a sykes pickavant tool for under £30.00 but dont know as id use it again,although it is supposed to be universal seems a bit much for a 'one off'.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You can improvise the rewind tool.
    I made one using a large bolt and welding 2 small pins to the head. Others have used snipe nose pliers to do it. A 'G' clamp to apply the pressure and turning the piston is all that is required - and some care in what you are doing so you don't apply too much pressure with 'G' clamp.
    I agree, buying a tool for £30 for essentially a one off job seems expensive.
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Laser do one, but as said for one job it's quite an added expense. Part number is 4331 if you're really keen, doesn't look a bad bit of kit actually.
    Regular Member DarrenLee's Avatar
    Shipley, West Yorkshire
    My brake pads are in need of a change soon - have been looking at greenstuff and mintex. Just dont know what to choose.
    Sheffield
    Trim : Sri
    I can't speak for greenstuff but I recently fitted Mintex to mine all round and I'm very happy with them.
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
