Thread: Whats The Cost Of A Cim ???
    Regular Member vectra-c1000's Avatar
    in a veccy
    Exclamation Whats The Cost Of A Cim ???
    CAN ANYONE TELL ME THE COST OF A CIM FOR VECTRA C 2.2 SRI DTI 52 PLATE JUST FOUND OUT THATS WHAT I NEED AFTER 3 MONTHS BUT I NO NOW THATS THE MAIN THING...
    Yikes, caps lock is on the left m8!
    From a dealer, the part is around £300 I believe - plus it'll need to be programmed into the car.
    What's the problem? i.e. why do you think it's the CIM that needs replacing?
    Regular Member Itsallrover's Avatar
    Aug 2007
    in an M&S somewhere in the South West
    Yeah should be around £300. I had problems with the spanner light coming on and after Vaux had cleared the fault codes twice they then said it needed a new CIM etc. I declined at the time (3 months ago) due to the cost and have not had the spanner light come on since. Mine is a 02 Gsi.
    I will not be replacing mine until I have a proper problem but maybe you have had some real issues
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have one for sale £40 delivered
    Suitable only for single plug airbag system which is fitted to the Vectra C between 2002-2003
    P/N 13112786
    Delphi
    4536 9002
    0210300653
    XU
    in a veccy
    Key Not Start The Car Just Happened No Warning So Watch Out Just Had A Man Out With A Tech2 And Thats What It Reads.
    And I Will Try And See What Part Number Mine Is And I Need Someone To Fit It Though I Have A Guy Who Can Programme It In ??
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    for a brand new cim from a dealer they will charge you £250 plus vat and tech 2ed out and in again
    Quote Originally Posted by merikiito View Post
    this one is worth buying if merikito has the secruity codes etc from the old car it came from
    Northampton
    Engine : A20DTH
    Mileage : 88000
    It should be all tech 2'd out and ready to use. U should only need the security code from your own car. Please check this out tho
    in a veccy
    so merikiito do you have the sercuity codes from the old car as i need them to programme it to my car..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Take the steering wheel off and you should be able to see all the codes/part numbers
  1. How much did your car cost???
    By tomtaylor15 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2013, 05:42
  2. Just cost myself £650
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2011, 07:20
  3. How much does it cost?
    By Gortreck in forum General Chat
    Last Post: 25th July 2010, 20:04
  4. Whats the cost of a new inlet manifold and injector wiring
    By mondyvec in forum Diesel Engine related
    Last Post: 13th June 2009, 21:27
  5. whats it going to cost
    By bigron1988 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2009, 10:00
