Results 1 to 10 of 11
Thread: CD70 Radio code
    Regular Member bgm46's Avatar
    South Queensferry
    Default CD70 Radio code
    Hello,
    Can anyone tell me if the security code on my car pass is the
    radio code for a CD70.
    The reason i am asking is i have nothing next to my radio code and i am
    planning on disconnecting my battery to reset the spanner fault light.
    Thanks,
    Brian
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    The newer 'full canbus' units don't have a code, it's all installed/taken out via tech2.
    Disconnecting the battery won't affect the unit. (apart from losing the stations maybe)
    South Queensferry
    Perfect, cheers for the quick reply
    Brian
    11 Post(s)
    Quote Originally Posted by bgm46 View Post
    i am
    Have you resolved the problem that put it on in the first place?
    If it's remaining on when the engine is running, then you haven't.
    If it is remaining on until the engine is running, then it's only indicating a stored fault and will clear itself within a number of clean start ups / number of days without the need to disconnect he battery.
    [Ex]Admin Duncan's Avatar
    Can anyone tell me if the security code on my car pass is the radio code for a CD70.
    Security code is the car immobiliser code. Certain programming operations by Tech 2 will require this to be entered to allow the technician to proceed. As above, no code on the CD70 required after disconnecting battery.
    South Queensferry
    Big Dave,
    The spanner is only there until the engine starts, i caused it in the first place when i was spraying stuff called 10k boost into the air inlet (sprayed it in after the MAF sensor but had to disconnect the inlet pipe hence causing the fault).I have just connected the battery back up and the time/date has been reset but the spanner still shows upon switching the ignition on.
    The reason i was trying to clear it is that this morning on the way home from work i had 2 large puffs of blue smoke when accelerating, i sometimes get smoke but nothing like this so wanted to see if there was a problem by clearing any stored faults and keeping my eye on it over the next few days.
    Brian
    South Queensferry
    Cheers Duncan, was replying to previous thread. All connected up now and Radio is fine.
    Brian
    11 Post(s)
    Does disconnecting the battery actually clear stored fault codes anymore? It used to, but I suspect like anything else Vauxhall, it'll need tech2'ing to have them cleared (or as mentioned earlier, so many clean start ups/number of days.
    South Queensferry
    i will just wait until it clears via amount of engine starts, i searched previous posts earlier to see if it can be reset so was worth a try.
    Time to start annoying the neighbours with constantly starting it!
  1. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  2. Radio Code
    By dazzh in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2010, 13:53
  3. CD70 navi radio code
    By lloyd_456 in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2009, 22:08
  4. radio code
    By ADAM123 in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2009, 00:07
  5. radio code
    By jamesv6 in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2006, 16:29
cd70 enter security code
