Results 1 to 10 of 13
Thread: paint airbox
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default paint airbox
    hi does anyone know any silver carpaint that will be an exact match for the colour of the engine, i am wanting to spray the airbox and battery cover and want it all the same colour
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    try alloy wheel colour spray mate, and make sure you use plastic primer first
    Midlands Mod Shop - NFFC.
    Regular Member DarrenLee's Avatar
    Shipley, West Yorkshire
    I am going to match the car colour to the engine bay plastics myself soon so this would be helpful so I dont screw it up.
    So I need:
    - PLASTIC Primer
    - Car Colour Spray Can
    - Lacquer
    Is that all?? any tips??
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Hi guys, Just a suggestion, i order paint for bits and pieces from www.paints4u.com there very good to deal with and pretty cheap. They can colour match paint for you. Hope this helps for any future refrence too
    Cheers Woody
    Trim : Get a
    that's all the paint sorted, firstly clean and de-grease all part's then when clean rub over with a scotch brite type pad / wire wool/ sandpaper to key the plastic, then clean again.....about 3-4 coat's of primer, gentle rub down with fine wire wool or same when properly dry, then paint, alllow to dry propperly then load's of laquer the more the better
    hth
    Regular Member EURO G's Avatar
    n ireland
    if you want to do it properly youll need grey scotch brite to key the parts then some panel degreaser, plastic adhesion promoter,some plastic primer,basecoat ie car colour,clearcoat and some p1500 sand paper to remove anybits of dirt when finished etc and some cutting compound to bring the paint back up to a gloss finish,just give yourself plenty of time between coats and be patient. hth
    n ireland
    to slow ditch got there before me lol
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    did mine mate as above method .the paint i used was from halfords their alloy wheel spray in a big tin think it was £6.99
    Trim : Get a
    Quote Originally Posted by stepheng View Post
    yeah but i forgot the cutting compound bit
    n ireland
    no one would have noticed mate shoulda kept that one to yourself lol
  1. Replies: 2
    Last Post: 17th November 2012, 11:24
  2. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  3. 2.8T Airbox
    By parapaul in forum Petrol Engine related
    Last Post: 16th August 2008, 21:21
  4. Airbox mod on my Pug
    By neilshaw1980 in forum Non Vectra C/Signum Album
    Last Post: 4th August 2008, 12:32
  5. normal spray paint or caliper paint?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 20:59
