Thread: what is a Swirl valve? how do i know if mines got a prob?
    Regular Member Craig1985's Avatar
    harwich essex
    Default what is a Swirl valve? how do i know if mines got a prob?
    sorry but keep seeing people wit problems wit swirl valve?
    so-------------what is a Swirl valve? how do i know if mines got a prob?
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    If you have a 1.9cdti 120 don't worry, it doesn't have them, if you have a 150 it does. Basically what they do is vary the inlet tract length to either give more torque or power dependant on demand, a clever little engineering trick that works, until they stick!
    I am under the impression that later models were fitted with a modified inlet manifold, someone will correct me if I'm wrong I'm sure, I am led to believe that mine was fitted with the modified version when it was changed.
    If it does develop a fault you will experience a serious loss of power, limp home mode is incredibly limp!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Thats correct they have modified the swirl valve (inlet) on the new´er parts. just got mine changed today after that error.
    harwich essex
    mine is 1.9 150 on a march 07 reg? will i have the mod?
    Engine : 2.2 Direct
    Not sure...
    Sheffield
    Trim : Sri
    If you have a friendly dealer they could have a look and tell you the date break on the part change, or maybe someone on here with TIS could tell you, I don't have it any more
    Regular Member martind511's Avatar
    Swindon
    Vehicle : Audii A3 Sportback
    Trim : S Line Black Edition
    Engine : 2.0 Diesel
    Year : 2011
    Quote Originally Posted by vectra1.9cdti View Post
    My 56 Plate 1.9 150 didn't have it - its a very weird experience when it goes - your foot is flat to the floor and the car doesn't respond at all for a few seconds and then off it goes at full pelt - totally intermittant. Got it changed under warranty
  1. Swirl valve bar off....
    By johnnyboy1985 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 17:04
  2. Egr valve, swirl valve problems etc..
  3. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  4. Dump Valve prob
    By the stig in forum Petrol Engine related
    Last Post: 11th October 2009, 18:00
  5. Swirl Valve
    By parsco in forum Engine & Drivetrain
    Last Post: 29th April 2009, 20:47
