Results 1 to 10 of 11
Thread: Don't park facing up hill if you drive a DTi.
    Regular Member TKD Colin's Avatar
    Jan 2008
    london
    Default Don't park facing up hill if you drive a DTi.
    Anyone else had this problem?
    I normally park my car facing down hill ready to leave our dead end road but was in a rush yesterday so parked facing up hill instead of going to the end of the road to turn around.
    Anyway went out this morning jumped in turned the key and hey presto the ol' girl didnt want to know, just kept turning over without starting. Anyway I can see my bank balance taking a nose dive.......
    Spoke to my father in law (ex Vauxhall technician) turns out its a known probelm with the leak off pipes on the DTi. Just had to keep turning it over till it started, which it did eventually.
    Apparently there is a modification to the leak off system which prevents this from happening, which I will be having done when he services the car in a couple of weeks.
    Just wondered if anyone else had experienced this problem or am I just lucky and special.
    Full Member Big Sig's Avatar
    Its quite a common problem with the dti's unfortunately
    Regular Member simac's Avatar
    Wirral
    I had the same problem with my 2.0 DTI Vectra b (02 plate), it was repaired under warranty a couple of times but it happend again - hence I left it with them and bought the Vectra C I have now LOL
    Jan 2006
    carlisle
    Default Leak Off Pipes
    best thing to do is get the leak off pipes replaced and then fit a one way valve in the system to stop the fuel draining back to the tank
    Costs about £12 for the valve and about £50 for the leakoff pipes to be replaced
    Regular Member Islander's Avatar
    Barrow-in-Furness
    Had the same problem with an Omega 2.5 diesel
    Regular Member Led's Avatar
    Kings Langley
    confused
    I've had the same problem but only after the car wasn't used for a while (2weeks+ Holiday), ****** anoying. Mine was down to the 'o' ring on the fuel filter - the mechanic said there was 1 too many
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    I had the same problem with my old Vectra B and I had the leak off pipes replaced, problem is it still did it. When parking facing uphill once I actually heard a glugging sound of fuel running back. It turned out that the fuel filter housing had two seals fitted in it, the reason for this apparentlt being that the fuel filter housing is prone to distortion, another common fault apparently, Complete new filter housing cured the problem.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My old Vec B used to do it.
    I cured it by not parking facing uphill, sounds simple, but worked a treat. And I'm not being sarcastic for once.
    Sheffield
    Trim : Sri
    Mileage : 198,500
    Quote Originally Posted by Ste View Post
    Agreed, mine didn't do it if parked on the flat or facing downhill, started fine.
    N. Ireland
    my mk4 astra sri done this. 2 days in a row it happened at a job i was at. (nowhere else to park). once you got it turned and started it drove for miles before the petrollight even came on
  1. This is what happens when you try to drive up a snowy hill...
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2010, 15:27
  2. Don't park facing down a slope!
    By powelly1592 in forum Engine & Drivetrain
    Last Post: 6th March 2009, 13:02
  3. REAR facing seat SRI only
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2009, 21:37
  4. Anyone know this car park - Saffron Hill Mscp (NCP)?
    By MysteryElite in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2008, 02:04
