Thread: Headlight bulb replacement
    Newcastle upon Tyne
    Question Headlight bulb replacement
    I know this has problably been posted before by somebody else, but I here goes.
    I have a 53 plate vectra (pre facelift) and I need to change the main beam bulb on the driver side, is there an easy way of doing this ?
    I have read some entry's that suggest its easier to take the whole headlight unit out, but can I not just replace the bulb without doing this ??? If so how ???
    Help !!!!
    either take the headilght out, or take the airbox out....airbox is easiest..
    disconnect the pipe leading to the engine by undoing the jubilee clip and sliding the pipe off..The airbox is held in on push studs, so from the back corner nearest the brake master cylinder, pull it up.. the airbox will rise and come out.. you now have loads of access to the back of the lamp..
    when you refit it, just make sure the front air hose locates properly.. push it down firmly and replace the hose.. job done..
    Newcastle upon Tyne
    Thumbs up Cheers
    Thanks for that, I will give it ago tonight.
    Newcastle upon Tyne
    Question Headlight bulb trouble
    I have managed to move backward the air box and get access to the bulb holder, but I am unable to get the bulb or the holder out to replace the bulb. Do I twist it or is there some sort of catch that needs to be losened ?
    Full Member Big Sig's Avatar
    there is a type of metal spring clip to undo that holds the lamp in.
    PM replied to..
    Regular Member simac's Avatar
    Wirral
    PM replied to also. The bulb holder comes out be twisting it gently about half a turn.
    I managed to do it without removing the air box or anything, just removed the cover on the light. I must have diddy hands LOL
  1. headlight bulb replacement FACELIFT
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2012, 18:42
  2. Headlight Bulb Replacement
    By safrav in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 15:07
  3. Headlight bulb replacement?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2010, 17:33
  4. Headlight Bulb Replacement
    By Hallzer in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2008, 16:12
  5. Headlight bulb replacement
    By Davexctra in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2007, 17:06
