Results 1 to 10 of 11
Thread: is it possible to add T/C
    Regular Member Craig1985's Avatar
    harwich essex
    confused is it possible to add T/C
    just wondering if its possible to add T/C to my 07 vecy diesel?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Do you not have it as standard?
    Always thought the Diesels did.
    Gazza4
    not really......anything IS possible, but the cost of parts/programming etc etc normally makes it too expensive to contemplate..
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you will need to take out the blank covers one the right side of the stereo and if you have one that has a blue plug behind it then you will need a t/c switch to see if it works
    harwich essex
    think is a blue plug? surly need more than a switch tho?
    no my EXCLUSIVE not got T/C onlly SRI and above models on facelift?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Do you get this symbol when you switch on your ignition:
    Also if wheels start to slip it will blink.
    If the light is no there, highly unlikely you have TC, the next thing to check according to other threads is if there is a grey/silber box with four pipes coming from it - which sits behind the battery/fuse compartment in the engine bay.
    Gazza4
    Regular Member bish's Avatar
    peterborough cambs :P
    Can this be fitted to a pre-face 1.8 ls??? i try and pull away fast-ish and just bl**dy spins, just get people looking at you
    harwich essex
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    dont get light.......and deff spins in this snow and ice lol
    ill look for that box 2morrow then, cheers
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    TC fitted as standard to all engines except 1.8 petrol on pre-facelifts. Apart from some early facelift Vectras , where TC was fitted as on pre-facelifts, only standard on facelifts on Vectras with V6 engines.
    If your car didn't come with TC you can't add it by fitting a switch. Even on pre-facelifts if your car came with TC, you cant guarantee that fitting a switch will make it switchable. Works with some, and not with others.
    AFAIK, TC is only available on the facelifts as part of the ESP option, which is only fitted as standard to V6-engined Vectras.
    harwich essex
    Quote Originally Posted by john_k_sri View Post
    answers that one then!!!!
