Results 1 to 10 of 13
Thread: error/fault code
    Default error/fault code
    With the help of a fault code reader - thankd Big Pete - I managed to read my cars fault code. P0105 - Generic, Map/BARO Circuit malfunction.
    It only does it in 4th on 75% throttle at about 3000rpm. Any ideas anyone????
    check and clean the boost pressure sensor.....
    Thats what I was thinking, it was replaced about a year ago. Errrm, do you know where it is????
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    This info is for a Signum 2.2 direct but will probably be similar dependant on your model.
    Intake manifold pressure sensor:
    Pressure sensor voltage 0 - 5 volts, engine switched off at sea level 4.5 to 4.8 volts, the value is governed by local conditions, altitude/flutuations in atmospheric pressure. Engine warm and idling accelerator pedal not actuated, 0.5 to 1.1 volts.
    The value increases with a brief opening of throttle valve (accelerator)
    Check power supply of component, ignition off, plug connection unplugged, measurement on wiring harness end of terminal C (+) to terminal A (-) ignition on value should be 4.8 to 5.3 volts.
    under the bonnet....
    it's on the main inlet plenubm...my bet is it will be caked in oily residue
    So where would it be? on a V6 CDTi????
    edit: Mark, I'm sure I've been told a funny version of that joke
    I'll see what I can see tomorrow. I take it its under the engine cover somewhere, multi plug on it?
    yep under the cover.. look central....yes, electrical plug on it..
    ok, thanks
    Quick update. Removed all sorts of bits trying to find the boost sensor (in the pooring rain!) only to find the sensor has "boost" written on it Still, it was covered in crud, its cleaned and only a test will tell
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Hopefully it will have done the job and be ok..
    Ps: i liked marks 2nd reply.. It did make me chuckle
  1. FAULT CODE HELP: p0380-08 glow device general error
    By merikiito in forum Engine & Drivetrain
    Last Post: 19th November 2011, 17:28
  2. Vectra SRi C alarm keeps going off code error fault
    By Tapie in forum Vectra C / Signum Troubleshooting
    Last Post: 8th September 2011, 20:53
  3. Spanner light; error code 'Preheat delay fault'
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 24th April 2009, 16:33
  4. Fault/Error code - misfire on cyl 1, 3 & 5
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 20:44
