Or is an itrip my only option?
Its an 06 Sri Vectra, as far as I can see there is no Aux so I'm guessing this cant be done? Would just prefer a crisper connection than the itrip offers.
Rik
Rik
Check this out.......i have this connected to my CD30 Factory HU, works a treat, good quality and no bad fm signal like an itrip!
http://forum.vectra-c.com/showthread.php?t=41750
Sorry cant be done .I use an fm transmitter not to bad reception
Can be done via Denison Ice Link as per my post above (With Photos)
This is a wired FM solution so all signal goes directly into the back of the stereo and is not transmitted over the air.
No loss of quality, no bad signal, only downside is the ipod can't be controlled from the head unit, it even charges the ipod and pauses it when you turn the ignition off.
Best Solution I have found for the Factory Headunits.
Edit: By the way I now have the ipod in the arm rest so noone can tell i have the denison solution in the car!
sorry to be a thicko....
does this have a plug that goes in place of the fm aerial lead, and then the fm aerial lead plugs into the adapter?
You could always just solder additional wires onto the volume control and select cd with no cd in the drive couldn't you, effectively a post pre-amp input???
I have no idea how that would work.
Im sure I would just blow it up knowing my luck.
