Results 1 to 10 of 17
Thread: Cleaning Turbo
    Larkhall
    Default Cleaning Turbo
    How do you clean the turbo?
    My car seems to be lacking power and i heard that cleaning the turbo and boost hoses can make a difference.
    Is that a load of sh*te or can it be done?
    you won't clean the turbo...simple as....and all the boost hoses will have in them are air and a light oil film...
    being fed a line Tam..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Removing the pipes, and cleaning any large accumulations of crud out will probably be a good idea, before it comes unstuck and either gets blown into the engine, after cooler or sucked into the turbine.
    As to power increases, only if the pipes are very restricted would you notice anything huge.
    Cleaning the turbo shouldn't really be necessary. BUT, if you feel you must do it, a lint free cloth with a dab of petrol would be OK to wipe around the parts. DO NOT dismantle your turbo.
    Cleaning the turbo?!! The only way it would make a difference is if say the turbo was a variable vane type and the vanes had got coked up and were sticking in the open position, therefore giving greatly reduced boost. Giving the turbo a clean up/de-coke would resolve that.
    Unless you're confident in that area, you wouldn't want to be taking a turbo out on a whim, and you certainly don't want to be poking around the impeller area if you don't know what you're doing.
    Larkhall
    Thought it sounded a load of sh*te. I put a fuel cleaner in the tank last month and noticed a slight difference but the car feels very sluggish
    Feb 2006
    Guttedsville
    Thoroughly check the boost hoses then, make sure they aren't split or perishing, or loose even.
    Regular Member EARLEY's Avatar
    Oct 2007
    Liverpool
    Have you just been looking at the performance figures for the CDTI mate.......hehe
    Quote Originally Posted by Ste View Post
    Sorry guys.. gotta ask..
    now we all know that you should not dismantle your turbo unit unless you have the correct rebalancing equipment ( very highly unlikely).. so , given that the impellers run so close to the casings ( to generate pressure they need to run tight) how do you propose that TAM pushing a petrol'd rag into the turbo to 'clean' it is A) a good idea as pieces could come off into the turbo.. b) the petrol will have a degenerative effect on the oil seals on the turbine shaft c) if you loosen any carbon how do you propose to make sure it's come out?..
    Tam, a turbo isn't a cleanable or serviceable unit unless it's in the hands of trained professionals.. DO NOT attempt anything on a DIY basis..any minor carbonising of the exhaust impeller chanber is fine, and you will find little to clean on the air compressor wheel housing side...99.9% of whats in there is just air with very very minor amounts of oil mist on the pipes walls...
    Larkhall
    Don'y worry, i'm not planning on taking anything apart on the car!!!!
    Hey, I wasn't suggesting Tam went anywhere near his impellers (unlike Ste! )
    When I said "...and you certainly don't want to be poking around the impeller area if you don't know what you're doing."...I maybe wasn't clear enough. What I meant by that was he doesn't want to be poking around the impeller area if he doesn't know what he's doing i.e. the people who do are the turbo specialists who would take the turbo apart to properly decoke it.
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Cleaning turbo with mr muscle without removing....
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 13th November 2012, 21:45
  3. Turbo cleaning?
    By Marty J CDTI in forum Diesel Engine related
    Last Post: 4th June 2008, 10:06
how do you clean a turbo on a vectra diesel
