Results 1 to 10 of 29
Thread: 2.0 T SRi springs 07 Estate
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Default 2.0 T SRi springs 07 Estate
    As the title says... full set of SRi springs from my 07 estate, they have covered 14,000 miles
    May fit other models but unsure... you lot will know im sure
    Collection prefered from Luton or im prepared to meet for fuel cost
    Looking for £40 ovno
    Postage would be via courier at £15
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Great price mate!! Unfortunately the wife won't let me lower her car.But good luck with your sale.
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    Anyone know if these would fit a Signum 1.9CDTi Elite. Presumably physically they would fit as the floor pans are the same (or not?).
    I'll check my weight codes tomorrow, but would be interested if they would be OK.
    they should be fine if the front weights are the same... your handbook will give you the other cars axle weights..
    Regular Member shan's Avatar
    Quote Originally Posted by 24vElite View Post
    They will fit fine. And give you a 15mm drop.
    May 2007
    On the Levels
    15mm drop and cheap as chips!
    oh well.. I tried..
    sent you a PM too
    dunno what im looking for but as follows on the plate;
    2125 kg
    3800 kg
    1-1040 kg
    2-1100 kg
    Tyneside
    1-1040kg is the front axle weight.
    Quote Originally Posted by blue estate View Post
    sent you a PM too
    1-1040 kg
    2-1100 kg
    Thanks these are the codes I need.
    Now I need some help from any(every)one.
    Codes on my Signum are
    1 - 1120
    2 - 1080
    So I'm quite happy with the rears as they are close enough. However there is a 80kg weight difference on the fronts. Does this mean that the front will drop lower due to the weight or is there too much difference between the two and the springs will be too soft?
    Any techies who could help?
    oh well.. I tried..
    bump... anyone know?
  1. Estate rear springs.
    By tyreman in forum Suspension, Wheels & Brakes
    Last Post: 30th October 2012, 15:26
  2. Will Hatchback springs fit Estate??
    By kev.whitehead in forum Suspension, Wheels & Brakes
    Last Post: 9th June 2010, 12:22
  3. Coil Springs Estate
    By vcdti in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2007, 17:47
