Results 1 to 10 of 19
Thread: gear knob pops off
    Kent
    Default gear knob pops off
    My 55plate gear knob in my veccy pops off! it does it at really annoying times like accelerating when I'm about to change gear it just appears in my left hand or in the passenger footwell! I don't know if its possible to glue it because of the reverse function where you have to pull the bit into the knob itself. However, I went to my vauxhall main dealer in Tun Wells and they say it will cost me £139 because it needs a whole new gear stick set...surely not! Why do they not cover things like this in the warranties?
    it should be covered under warranty...
    if they refuse to cover it.. superglue it to the shaft again, just don't hit it on with a hammer.. it'll go down too far and you won't be able to select reverse..
    just glue it with superglue or epoxy and leave it to cure.. it'll stay on..
    Kent
    but the spring and foam move up and down inside it leaving it just 10millimetres right on the top to glue to the shaft...
    the spring will compress down as the knob is replaced... put the glue into the knob and put the knob onto the shaft firmly..
    Regular Member Matty H's Avatar
    Bristol
    I had a Y reg Zafira that used to have this problem. I also glued it on. It was fine
    Kent
    cool, thanks, i'll try it in the morning. May save me £139, what a rip-off though. I asked them if its the same price for a sri or vxr knob and they said I'd be lokking at £200. I nearly fell off the floor. lol cheers
    Regular Member garvey's Avatar
    Co Durham
    wish I could change my knob its looking very tatty
    Bristol
    Quote Originally Posted by garvey View Post
    Boom Boom!
    Kent
    garvey, just pull it lol may work, if you pull it whilst your in 2nd, 4th or 6th for those lucky enough to have it, it may just pop off eventually, not advised, just a shame mine happened without me wanting it to.
    if you want to change the gearknob, just tap it upwards with a hammer from underneath and it'll come off....
  1. show me your knob (gear knob)
    By justin32 in forum Bodywork & Interior
    Last Post: 10th October 2011, 19:18
  2. 5th gear pops out...
    By CrowdPleazer in forum Engine & Drivetrain
    Last Post: 14th April 2011, 13:28
  3. Play in my knob gear knob lol
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 16th June 2010, 08:20
vauxhall vectra gear knob falls off
vectra gear knob pops off
gear knob popping off on a vauxhall vectra
gear knob popping off vectra
vectra gear knob popping off
vectra c inside gear knob
