Results 1 to 10 of 14
Thread: Help..can't get the wheel locking nuts off!
    Berks
    Default Help..can't get the wheel locking nuts off!
    I had my day planned. I was going to paint the calipers and bought all the stuff I needed......Only to find out I can't get the darn locking nuts off...from any of the wheels.
    I have an 04 1.9 CDTI SXI.
    On one of the locking nuts the ring has gone (no idea where!) on the other 3 nuts I just can't get them off. When I try the key just slips off...
    I went to Halfords to buy some locking wheel removers that you supposedly screw on. That didn't work at all..
    I popped into KwikFit.Ii don't like kwikfit but it is Easter Monday and I was due an oil/filter change and their cheap...they had no luck either and told me to go to a vauxhall garage!!
    Any way of getting these off without having to go to a stealer? I'm pretty annoyed since I had my whole day planned...only to go down the drain due to these stupid locking nuts.. Must be bad quality!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Have the nuts rounded off? They are really soft material and my advice is get to a dealer and leave the nuts (pardon the pun) alone.LOL
    Gazza4
    the locking nut removers rely on that outer ring being off the bolt... so if you want to use them you'll have to get the rings off the other 3.
    I don't know about the halfords removers, but the snapon one's i use have 6 'teeth' that bite very hard.. never let me down yet....
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    If you are using the VX wheel brace then don't. It's not at 90 degrees. Try a 17mm socket and handle thing pusing it onto the nut.
    When I couldn't get mine off I called the AA and said I had a puncture at Home. AA man came out and used a cold chisel to "sharpen" the key.It worked. I just don't put then on tight anymore.
    Berks
    I'm not using the standard VX wheel brace. I've got one I bought from Halfords (one of those 4 in one cross things).
    I had my car jacked up to see if I could jolt it off somehow if I took off the other 4 normal nut...that didn't work either, the damn wheel didnt move at all....
    However, when my car was jacked up I noticed some play in right rear wheel!! I put the axel stands on, put my head under there and rocked the wheel. I could not see where the play was. It only happens when I shake the top and bottom of the wheel, not right and left. This is probably the answer to the knocking sound I get when I drive over uneven roads!
    I'll have to take the car into the garage tomorrow morning to have it looked at, so I'll ask them to get the nuts off as well!
    Feb 2006
    Guttedsville
    Just a guess, but you'll need some of these......
    http://www.lmfvauxhall.co.uk/store/p...at=1444&page=1
    top/bottom rock is normally the top arms void bush worn out...that would cause the knocking.....
    get it looked at while they rip off the wheelnuts..shouldn't take long with the right ripper socket..
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    same as mine Mark , i had the same trouble with the Elite about 7 months ago i chipped the ring of the nuts (took ages as i didnt want to damage the alloys) then the extracting sockets pulled them off ,
    ive just put a standard stud back on , to avoid it happening again
    Quote Originally Posted by AndrewTi View Post
    good guess......
    Berks
    The locking nuts are now off. They charged me £35 for the pleasure..He said it took him half an our and he struggled a lot using his drill...
    Your guess was partly right regarding the knocking sound...
    The upper suspension bushes are worn. That's the same as the rear control arms right?..Apparently i cant buy just the bushes, it comes with the arm..
    I also had a broken rear coil spring!!! I was told that the broken spring needs immediate changing and i should not drive the car... The control arms is not so urgent and can wait. Which is what I've done to space out the costs a bit. I checked the spring myself a couple of weeks ago but saw no signs of damage...perhaps its my untrained eye (im a newbie when it comes to car DIY)
    Question. The garage couldn't say if the play in the wheel and knocking sound from driving over uneven road came from the suspension or the bushes being worn...
    Anyone of you experts out there have an educated guess? I'd love it to be the suspension as I'm fed up with the noise....?
  1. locking wheel nuts
    By Liam1984 in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2010, 20:35
  2. locking wheel nuts
    By tommy tess in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2009, 19:19
  3. Locking wheel nuts
    By johnny kebab in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2008, 19:03
  4. locking wheel nuts
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2007, 22:14
  5. Locking wheel nuts
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2005, 16:33
