Results 1 to 2 of 2
Thread: DVD Help
    Regular Member purple170503's Avatar
    kent
    Default DVD Help
    A few years ago I bought a Toshiba SD220E DVD Player in multi region. A few weeks ago the multi bit just stopped working. having done some research it looks like this is quite common with this model and found a 'hack' to return it to it's former glory but it doesn'y seem to work.
    Are there any technical experts around that could help?
    Nicking Ya Dinner.
    Probably because you've changed the region without knowing more than 5 times if they are firmed up the same as a PC drive, what you need to do now is go to the Tosh site and download the latest firmware if it's available, burn this onto a cd-r and insert it in the player, onscreen should pop up and hopefully re-prog it for you. hth.
