Results 1 to 10 of 13
Thread: Ball Joint failure
    May 2007
    north wales
    Default Ball Joint failure
    Hi,my 1.8 52 plate Elegance has just failed its MOT on the following;
    "Nearside front suspension joint has excessive play in a lower suspension ball joint".
    Local garage is doing the repairs on Tuesday,but mechanic seemed unsure whether repair required a replacement arm or a push-in something or other(sorry I'm not mechanically minded!).Quoted about £40 for the parts and less than an hours labour.Any thoughts on this please,before I take it in.Is this a common failure - I haven't noticed any vibrations or steering problems.
    Pete.
    not overly common...I don't know if pattern arms or balljoints are avaliable yet for the C, but given the choice, replace the entire arm...
    Regular Member EURO G's Avatar
    n ireland
    think the arms r only available in one piece got quoted 55 + vat for the arm thats a pattern part
    May 2007
    north wales
    Thanks Guys,
    let you know on Tuesday, after it's been done.
    Pete.
    Regular Member garvey's Avatar
    Co Durham
    Quote Originally Posted by stepheng View Post
    that seems a bit much
    nah, not really..... genuine arms used to be over £100 a side....
    n ireland
    not 100% sure but i think its cause the arms are aluminum?
    yep, cast rather than the old spotwelded steel pressings...
    May 2007
    north wales
    Job done Yesterday.Part cost £69 and mechanic charged for half an hours labour.Checked underneath, and yes it's a nice shiny aluminium arm.Drove it home but noticed a knocking from front end.Took it back in today,and mechanic showed me that when the front suspension is "bounced"on the side he fixed,there is a clunk from the top of the suspension strut.Says its nothing to worry about and nothing to do with what he did.Any advice?
    Pete.
    he's have not touched to top of the strut.. no need to...
    sounds like a worn/wearing top bearing mount on the strut..
  1. MOT Failure Anti-roll bar linkage ball joint problems need advice
    By Bartekuk in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2013, 13:10
  2. spinning ball joint
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2011, 21:09
  3. Ball joint issues
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 21:46
  4. failed MOT ARB Ball Joint
    By howieallstars in forum Handling & Braking
    Last Post: 15th November 2010, 16:50
  5. Gearknob ball joint
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 21:57
vectra c ball joint failure
