Results 1 to 10 of 27
Thread: Standard CD player and cruise control question
    farnborough
    Default Standard CD player and cruise control question
    looking at an SXi are the standard cd players any good?
    also, how does the cruise control work??
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    I have the crd2005 unit in my car an IMO its crud. keeps skipping cd tracks on cold mornings.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Smile
    If you have cruise cxontrol fitted the controls are on the end of the indicator stalk on the left side of the steering wheel. The front switch of the 2 is divided into 2 functions, the bottom part is the resume and speed incremental decrease and the top part is the set and speed incremental increase.The very back switch will disable the cruise control once it is ON as will the clutch and brake pedals.
    farnborough
    so basically drive along... push the top button then im cruising??
    and then to come out, tap the brake?
    Mileage : 000
    The CC will disengage when you press the clutch pedal too.
    farnborough
    is there a dash light to show it's on??
    need to check the one i'm looking at is all working correctly
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Smile
    Yes just to the right of centre on the bottom of the instrument panel a green speedo symbol strangely enough
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It won't work until you above approx 20mph though.
    farnborough
    thanks Paul
    Mileage : 000
    And you have to press the brake after the igintion is switched on or it will not work either.
  1. Another Cruise control question!
    By Darren1843 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 13:37
  2. cruise control question
    By glens14a in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2010, 09:07
  3. Standard CD player
    By winty234 in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2010, 13:01
  4. SatNav on a standard in car dvd player
    By jaxouk in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2008, 20:27
vectra c cd keeps skipping
vectra c wont engage cds
