Thread: help with washers
    Regular Member cdms811's Avatar
    Newcastle
    Default help with washers
    how do i unblock the filter on the washer tank?
    I think there maybe a how 2 for this, but remove n/s wheel and arch liner to expose the washer bottle, remove pump and the filter is exposed, either clean it or cut it out, its up to you
    Regular Member bravocorsa's Avatar
    Jun 2007
    birm
    Thumbs up
    as posted the other day by moi!!!
    cheats method: 1) jack up pass side of car and support with axle
    stand!!!
    2) turn wheel full lock right (if i remember!) to show 3/4
    small torx screws, undo said torx screws and pull inner
    wing gently back.
    3) should be able to see washer pump/motor sat in
    washer reservoir,disconnect electrical plug and
    remove with a gentle pull/wobble movement.
    4) the motor will have a little rubber gauze boot/ cover
    on this will
    be (hopefully) bunged up with bluey green
    screenwash concentrate, remove and wash through.
    5) now its upto whether you try as is after reassembly
    or put a small slit with some side cutters
    (as i have done about 6 times on
    different cars with no probs) then put back together!
    ** forgot to say be prepared to lose your screenwash contents!!!
    hope this helps and fixes your prob.
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    i'm going to have to do it too, only had the car 3 weeks and noticed the washers slowing down and taking a little longer to come on. i thought i was running out of water, so took the lid of and found the dip stick has blue slime on it, so i suspect a blocked filter too
    Woody
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Have you tried syphoning out the slimy water and adding boiling water try this a couple of times it worked for me as the boiling water disolves the slime, mine work fine know, the blue slime was the washer fluid additive, I added too much.
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    Happened to me, followed the How2 on here about 6 months ago, exept I cut the rubber mesh bit off, Washers are now like a jetwash !
    Newcastle
    or a smigin of mr muscle sink and plughole unblocker !
  1. headlight washers??
    By vauxhall-john in forum Bodywork & Interior
    Last Post: 4th January 2011, 13:21
  2. Washers
    By jlock in forum Bodywork & Interior
    Last Post: 8th March 2010, 21:04
  3. Got some new washers
    By lizard in forum Handling & Braking
    Last Post: 12th September 2009, 20:04
  4. headlight washers.
    By Netstar in forum Bodywork & Interior
    Last Post: 2nd March 2009, 16:18
