Thread: outside temperature sensor
    Regular Member billyyoung's Avatar
    dundee
    Default outside temperature sensor
    My car has decided to start playing up , the tempersture sensor for outside is reading a cool -40c . have changed the sensor today but with no luck , should i disconnect the battery to reset it .Has anyone one else had a similar problem
    it normally resets itself automatically.... plug terminals clean and free from water?..wiring all good?..
    dundee
    yeah the plugs are good sprayed a little wd40 to get rid or any water that may have been there and put some electrical grease on the terminals. checked the wiring as far as i can see think ill need to follow it all the way back now
    wouldn't be the first time a replacement part has been proved faulty either....they are massproduced don't forget...
    not got a mate with one you can 'borrow' for 5 mins have you?.
    Regular Member NI-2.2SRI's Avatar
    Northern Ireland
    i got mine changed when i bought the car, took it a few days to come around, wud take an odd turn an jump up r down, was fine after a few days.
  1. Outside temperature sensor gone mad!
    By devore in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2013, 16:58
  2. Outside Temperature Sensor
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2009, 23:35
  3. Outside air temperature sensor
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 13:31
  4. Outside Temperature Sensor
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2008, 10:59
  5. Outside Temperature Sensor U/s
    By turnerk in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 22:05
