Thread: vec c 1.8 04 plate slow pick up
    Regular Member chinky's Avatar
    midlands
    Default vec c 1.8 04 plate slow pick up
    on pulling away car is hesitant as if short of fuel a bit like turbo lag in a diesel and requires higher revs this happens hot cold any help plz
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    If it is a high milage car (over 40k) it may be that a new fuel filter is required. To fit it is a grovel behind the o/s rear wheel, OR, could the air filter be a bit filthy? OR, have you read the items about the air intake/filter box mods? Any or all of these could/may/might cure your problem.
    Full Member Big Sig's Avatar
    high milage, over 40k
    Regular Member djr69uk's Avatar
    Midlands
    40k? i'd call that run in!
    Jul 2006
    TENTERDEN KENT
    I think that 36k or 4 years is the milage reccomended for a fuel filter change on 1.8 petrol engines, that is why I used that figure, as over that figure could be seen as "high milage" for that part. I know that when I changed mine at 40k the fuel that came out of the old filter was totally black with sludge from the petrol, so changing it can only be of benefit to the engine. If you do change the fuel filter don't forget to use new clips in the Q/R connectors. Thanks for the posts lads, hope to hear from you again.
  1. Slow to pull away - dangerously slow to pull away (150cdti auto)
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 21:10
  2. could anyone do a pick up for me????
    By VECTRA1974* in forum General Chat
    Last Post: 31st July 2011, 22:04
  3. help me pick my new reg
    By peadar in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2010, 10:34
  4. Pick up new car
    By nokiaman1978 in forum Introduce yourself.
    Last Post: 2nd September 2009, 23:39
  5. 07 plate vectra wipers slow!!!!!!!!!!!!!!
    By mitch in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2008, 17:44
vectra c 1.8 running slow
vauxhall vectra 2008 1.8 I running slow
