Thread: Timing chain/belt
    Jan 2006
    Bray Co.wicklow
    Default Timing chain/belt
    Hi all,Great site
    When should the timing belt/chain be changed on a 1.8 petrol GTS 2003.
    Iam asking because of the clicking noise which is coming from the timing belt side of my engine,the noise can only be heard when the car is just ticking over,any ideas .
    Only 36000 on the clock.
    Regular Member suj786's Avatar
    glasgow
    I was told belts need to be changed at 40,000 miles
    I'm nearly due for my second replacement. U might want to get the tensioners done at the same time.
    Regular Member blr123's Avatar
    Dundee, scotland
    I'd be surprised if Vauxhalls recomendation was less than 60k miles, although that would also have a 5year time limit on it aswell.
    Bryan
    PS from the service book it looks like 60k or 6years although it doesn't mention the 2.0T or the 2.2 engines.
    Jan 2006
    Bray Co.wicklow
    Thanks for the help
    glasgow
    I done mine at 38,000 to keep the warranty valid. as it has to be done at 40,000 on the older 1.8 engine, the new engines apparantly dont need to have theirs done till 60k
    I'm now sitting at 72k so looks like they'll be gettin done again in the summer. not cheap man, cost me £220 the last time.
    40K for a timing belt is cr4ppy me thinks. if I knew that before I might have reconsidered buying the car, I'm changing belts every 2 years.
    Sweden
    Quote Originally Posted by blr123
    No belt on them, thats the answer why they are not mentioned.
    Dundee, scotland
    Quote Originally Posted by TechWolf
    .......no belt cool I can live with that
    Bryan
    Feb 2006
    Nr Liverpool
    My dealer told me 40k was the limit on my 03 1.8. Think i'll have it done before though to be on the safe side. Always have the rollers changed at the same time or your asking for trouble. Sounds like you've got a noisey bearing on a pulley mate, in witch case have the lot done for peace of mind.
    Regular Member denzo's Avatar
    Runcorn
    Vx told me the interval was 100,000 miles or 10 years on my car
    Regular Member Basil's Avatar
    Nottingham
    If I remember correctly the "ticking" sound you can hear is the tensioners.
    What happens is as the belt stretches over time, the tensioners pick up the extra length on the belt, but when belt stretch gets to a certain point, the tensioners can take up no more and they "lift and drop" hence the "ticking" sound, you may also hear a bit of a squeak when cold.
    On mine, the timing belt was on the left of the engine block as you look from the front, and the black plastic cover is a sort of curved triangular shape and covers the left side of the engine from back to front and top to bottom, if you listen here and it's where the ticking is from, it's your timing belt.
    This happened on my old 1.8 petrol vec, and I was told to get it changed sooner rather than later by two different garages, one of whom spotted it on an MOT.
    I would get it changed bud to be on the safe side.
  1. timing chain or belt
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2010, 19:58
  2. Timing belt or chain
    By geebee007 in forum Engine & Drivetrain
    Last Post: 4th September 2010, 22:46
  3. Timing belt/chain
    By Nicolas in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd September 2008, 06:46
  4. Timing chain or belt??
    By alid32 in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2007, 21:46
  5. Timing Belt or Chain
    By xrmatt99 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2006, 15:10
