Thread: sricdti estate 54 plate thinking of buying what faults to look for please
    braintree
    Default sricdti estate 54 plate thinking of buying what faults to look for please
    hi going to look at a vectra sricdti later its on a 54 plate its done 92,000 miles just want to ask what faults to look out for etc as i had a vectra a few years ago then went over to the vw passat but now need a bigger car for our new pet dog we are gettting soon (great dane)you help and advice would be great i will be doing a rac check of the car for outstanding hpi etc just need to know any major problems i could look out for thanks
    major problems?..
    Inlet manifolds let go of the swirl valve rod £400.. EGR valves give trouble ( no UK stocks at the mo)..Injector wiring issues..
    TBH, you need to buy this car with a warranty.. when they are working they are great cars.. but if you get a rogue you'll be needing that warranty..the 4 cylinder 1.9's are hit or miss, you either get a corker or a dog.. so beware..
    CDTi Engine apart, the vectra's are great cars..bomb proof and will absorb high mileages with ease...
    braintree
    thanks for the info as the car im going to look at looks great can get it for £5000 is that a good price for the miles its done how would i know if those items you where stating as faulty are going or have failed
    braintree
    any good warranty deals going around are there
    Regular Member PeteRs's Avatar
    here or there
    would get cambelt changed straight away i just bought a vec which has snapped it at just 55k
    braintree
    hi thanks for that forgot to ask them that if the cambelt was changed or not yet
    it won't be changed yet.. it's not due till 80,000 BUT i'd get one on sooner than that...
    unless you know where to look for the swirl rod i'll be hard pressed to explain it to you.. it's on the top of the inlet manifold under the plastic cover.. a bar with plastic balljoints on it..it should be clipped on, not laying loose..
    another 'easy' tip to see if it's got any problems is not to be too hasty when you start it....
    sit in, turn the key to posn2.. and watch the display in the tacho.. if a 'car with spanner' shows you know it's had a fault within the last 25 odd restarts ( fixed now or not).. if so, ask a few searching questions..
    A Cdti for £5000 is good money.... there is a thread here in car chat about warrantys, so have a look around..
    braintree
    brillaint thanks for that havnt heard back yet about the cambelt the car has done 92,000 miles so should the cambelt be replaced yet or not thanks
    yes, it should hve been done, or it needs doing now..worth another £300 off if it hasn't been done
    braintree
    ok still waiting for them to get to me on that one been looking at the warranty buts but most of them are just the basic ones due to the car has done 92,000 miles so they do not cover most of the main parts a/c abs etc any advice
  1. thinking of buying 2008 (58) vectra 1.8 sri estate ?
    By james dickinson in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 23:24
  2. Thinking about buying a 56 plate vectra but think its used red diesel
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2009, 15:08
  3. Thinking about buying a Vectra Estate
    By frenchman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 11:26
  4. Thinking of buying a 3.0 CDTI auto elite estate - your thoughts please
    By 3.2omegaestate in forum Introduce yourself.
    Last Post: 25th July 2009, 18:19
  5. Thinking of buying a Gsi
    By Mark2.2 in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2009, 21:22
