Page 1 of 11 123 ... LastLast
Results 1 to 10 of 110
Thread: TPMS (Tyre Pressure Monitoring System)
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Default TPMS (Tyre Pressure Monitoring System)
    Looking at another project on the car, tyre pressure monitoring system. This option is still available on certain Opel Vectra's but has been deleted from the options list here in the UK.
    Pre-facelift cars require a receiver on each wheel arch but on the facelift there are only two receivers required one front and one rear. From research it looks as though the receivers mount on the passenger side of the car. The front receiver is mounted behind the wheel arch liner and the rear one again behind the rear wheel arch liner.
    The system comprises of a control unit which mounts in the right hand side of the boot in the first aid compartment, two receivers as mentioned above and transmitter valves fitted to each wheel/tyre.
    It's looking as though cars fitted with AFL will have the harness already in place to connect the wheel arch receivers to the control unit. This I have to confirm but from browsing the German forums this seems to be the case.
    Below is a list of the parts required, bear in mind if you are interested in this mod then none AFL cars will require a couple of wiring harness which will be a nightmare to do and knowing the cost of wiring harness probably put the cost up massively.
    Control Unit 13172984
    Receiver front 13172992
    Receiver rear 13172977
    Wheel valve transmitters 13172567 X4
    Valve seal 9198632 X4
    Dust caps 93184614 X4
    Rear receiver Screw to body 11097151 X2
    Nut front receiver to body 90287467 X2
    Tech2 is required to program the system and to enable the colour display which displays tyre pressure and air loss. I'll be giving this a go in the near future and probably writing a 'how to'
    Paul.
    Jul 2006
    Brave man! Well done!
    Look forward to it Paul. I priced this up a while ago to fit to mine and it was starting to get a bit expensive once you added all the receivers etc., bearing in mind it would need four on mine. Decided that as I visually inspect the tyres regularly anyway it wasn't worth it, for me, to pursue it.
    Interested to see how you get on though.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    I remember pricing it up on my old motor D, it did get stupid. Should be a load cheaper on the facelift though with only needing two receivers and hopefully having the wiring harness in place.
    Yep, that'll help a lot. As you say, on the pre-face it was getting a bit silly price wise which is why I, and obviously you, never bothered.
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    mine is already underway,already got all the wiring there,
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by andy.l View Post
    Never!!! Just stumbled accross a potential problem. The front harness may well be there but there's a chance the rear one isn't. I would have thought if the AFL was fitted then the rear harness would be the top one but it seems not. There is one listed for AFL but without tpms which could be on mine
    Sunny Dartmoor
    Good luck mate..........
    Oct 2006
    Wellingborough
    Don't get too hung up on the harnesses, TIS shows pinouts for the modules in the car, so you can tap into the relevant can network from somewhere nearby (lets face it it's all over the car!) and then all you'll need is a power feed. But you first eh mate?
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by Flaninacupboard View Post
    Thanks!
  1. TPMS Tyre pressure monitoring system HOW-TO
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2012, 10:39
  2. Retro Fitting Tyre Pressure Monitoring System & Front/Rear parking sensors to Vectra
    By rich05uk in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 12:09
  3. For Sale: Genuine Tyre pressure monitoring system (TPMS) rear loom and recivers
    By John LE in forum Parts for sale
    Last Post: 6th January 2012, 02:42
  4. My aftermarket Tyre Pressure Monitoring System
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2009, 12:11
  5. Tyre Pressure monitoring system
    By dieselvec1 in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2008, 15:25
9198632 tpms
