Thread: side light prob HELP!!!
    liverpool
    Default side light prob HELP!!!
    ok here's the prob.main beam and dipped ok. side lights will not working at all with or without engine switched on. their is no dashboard ilumination ights when i switch the side lights on, also there is no bulb warning light on to sugest its just a bulb. could this be a fuse or is it more likely to be the switch.
    any help at all would very much appreciated,
    sounds like the switch if it's affecting the dash illumination as well.. lets just hope it's not the start of CIM failure as well as the dash illumination also runs through this module....
    Try a replacement switch first.. that would be my vote..
    liverpool
    thanks for the reply Gsi3.2, much appreciated. took your advice checked the switch like you said.
    took the switch unit out stripped it down and gave the contacts a clean with some nail varnish remover hey presto jobs a good un.
    when you say CIM failure am i correct in assuming that would be a lot of doller.
    around £400 to get supplied and fitted.. VX dealer only job....
    Glad it was just the switch matey..
    liverpool
    I rang the dealer up to quote me a price on a new switch £60. so that in itself was a bit of a kick in the do dah's. so well pleased thats all it was, a bit of a bad contact.
    once again m8 thanks for the advice a push in the right direction is always appreciated.
    keep up the good work keeping average joe in pocket.
    thats all i want to do.. stop folks getting ripped off when it's doable at home or by a cheaper source....
    Moneys better in your hand than the dealers..
  1. interior light prob
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 13:12
  2. Parking light/side light
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 11:14
  3. head light prob
    By wolfie1 in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2008, 20:14
  4. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
