Thread: Signum just cuts out!!
    Peterborough
    Default Signum just cuts out!!
    My 2003 2.0T Signum will just cut out at random moments whilst im driving it. Engine revs will drop, and you lose throttle completely and then the engine cuts out, even when taken out of gear and clutch engaged. If i then disconnect battery and reconnect it will start and run fine again no problem, but cut out again some time in the future??
    Have had numerous tech2 tests done at vauxhall dealer and changed an o2 sensor but no joy, my last phonecall to them led them to tell me i needed a new ecu at £700 +vat, and they not even seen the car or experienced the problem.
    Have been told that Idle Control Valve might be the cause, butt havnt the foggiest as to where to find it.
    Does anyone have any ideas/had a similar problem??
    all help greatly recieved
    cheers
    Chris
    the 2.0T doesn't really have an ICV...it just picks up via the electronic throttle butterfly..
    The ECU must have stored some codes...perhaps try a different dealer, or get the ECU's codes read by an independant as to just write it off over the phone shows just how interested they are....
    Peterborough
    thats what i thought, wasnt sure how they could tell the ecu was broken over the phone
    cheers
    they're just trying to cover themselves...
    even if it's faulty, an ECU will still give communication errors or other fault codes to point in the direction of the fault..
  1. Cuts out
    By JaceyBoy in forum Engine & Drivetrain
    Last Post: 17th April 2012, 21:24
  2. 2.0 Dti engine cuts out Signum
    By martutd in forum Engine & Drivetrain
    Last Post: 19th March 2012, 08:35
  3. cuts out
    By daddyjay in forum Engine & Drivetrain
    Last Post: 1st March 2012, 21:42
  4. Help Help HELP!!!!!! Starts - then cuts out
    By joek880 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2012, 04:02
  5. Signum 2.0T Engine Cuts Out
    By CallForRecovery in forum Engine & Drivetrain
    Last Post: 27th July 2011, 21:18
