Results 1 to 10 of 17
Thread: coolant loss
    Regular Member lilangel's Avatar
    bucks
    Default coolant loss
    right, i ve seem to developed coolant loss. was slightly under line about two weeks ago, so topped it to be sloghtly over the line and now its back to under again. so not a massive loss, but still loss. hopefully its sumthing thats covered by a warranty? also, read before that if something was repaired there would be a silver dot the coolant cap, which there is. can someone remind me what this would be?
    cheerios
    first, and most likely 'easy' cause.... change the tank cap ... they are well known for becoming weak and allowing hot coolant vapour to secape, making it look like coolant loss..
    i take it you have not other signs of trouble?..just the water going down?
    bucks
    what other signes could there be? i am just going on what the computer says...
    other signs?..
    If it's an auto then i'd check the fluid in the transmission carefully for water contamination.. is there any oil spotting in the header tank?..are there any water droplets coming from the driverside of the car when it's idling with the engine hot?.. is the oil on the dipstick it's 'usual' colour or is it lightly whiteish?..
    if you haven't got any of those then i'd swap the pressure cap ( it's only a few quid) as they are a favourite part..
    Regular Member david m's Avatar
    Oct 2007
    co.durham
    i had the same problem just a tiny loss of coolent,its not just the tank cap, ive just replaced the whole tank as it had a tiny split in it becouse the tank is two piece and sealed together there only 18quidish and easy to do.
    bucks
    hmmm....thnx for the suggestions, its a manual, 3.2 v6, and i am girl, appreciate the excuse now, lol, so most of the things u mentioned i have no idea about, lol
    thats no probs Lilangel.... in my household the girls fix cars as well....Mrs GSi's signum is all her own work..
    just look really hard for any water thats escaping ( any signs of it) around the coolant bottle... that would be a good start..if you dry it with a tissue all over then run the car for a day or so before rechecking.. it should still be dry if the tank and / or cap are fine.. any signs of loss are easily visible then..
    bucks
    lol will do! wish i could do it too, but have to say i like watching the pretty boys in my local garage doin it lol
    fair enough....
    if you do get stuck and aren't too far away we could always take a look for you..but dry it and see if you can locate it first..
  1. Coolant loss.
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 10th January 2013, 21:18
  2. V6 Coolant loss, Help!
    By v6boy in forum Troubleshooting
    Last Post: 12th September 2010, 16:01
  3. Gsi coolant loss
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 15:13
  4. Coolant Loss
    By george in forum Engine & Drivetrain
    Last Post: 12th April 2007, 06:39
  5. 1.8 coolant + oil loss
    By Aleco in forum Engine & Drivetrain
    Last Post: 15th March 2007, 21:52
coolant loss vectra c
