Thread: T/c switch ????
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Default T/c switch ????
    Hi guys, i've read some posts about fitting the switch in the blank cover 3rd down from the right. They mention there should be a blue plug behind it but it depends on whether you have the esp+ fitted or not for it to work. My question is i pulled the blank out and i did not see any plug at all does all vectra's have the plug. Maybe mine's dropped down behind. she's an 02 2.2 DTI
    Woody
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    some have them some don't it's all a bit hit and miss if they work, i fitted one to my car with the blue plug there and it does't work, light's up and look's good though, so not a total waste of money
    Midlands Mod Shop - NFFC.
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Oh well i think mine doesn't have it then
    cheers all the same ditchp
    Woody
    Mileage : 000
    It is set back a little but I would have thought you would have the blue plug behind the blanking cover. I don,t think the ESP+ makes any difference either. My motor is a 3.2V6 it had ESP+ as standard, but no T/C switch so I fitted the switch.......................................It did not work. It seems to be a bit hit and miss to weather it will work or not, there have been many threads about the T/C switch over the years, and it seems to work on some cars but not on otheres, there does not seem to be any set patern, it is not specific to any engine size or fuel age or trim, Have anothere look for the plug, if you find one then just buy thr switch and hope for the best.
    Regular Member craigmerry's Avatar
    Jan 2008
    midlands
    Do you just push it and hope it connects or do you need to find the blue plug
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    doesn't the car have to have the TC light show on the speedo for this to work?
    Trim : Get a
    Quote Originally Posted by craigmerry View Post
    yup just fit the button and hope for the best
    Quote Originally Posted by lofty View Post
    mine has the light on the dash but still doesn't work, ie doesnt illuminate when button pushed
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
