Thread: Cutting out
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default Cutting out
    Help required
    First thing in the morn, into 1st gear then pull away from a junction, when i then change into 2nd the car cuts out.
    its not stalling cos all the dash display goes off (when stalling/engine cut out alt/oil warning lights come on and mileage still displayed), but on this all dash display go out inc mileage and gauges . The car will restart but not nice as its the missus that drives it most. it has happened to me twice.
    Am thinking poss dash prob/earth fault.
    Only picked the car up on Saturday.
    Any ideas. Veh is a 04 3.2 Gsi only done 28,000miles
    Hmmm, possibly the cim in the steering coloumn. I think that controls the dash. If the car doesn't detect all parts via the canbus it could kill the engine. Have a search for CIM module.
    so, to clarify?.. is the engine still running?. or is it just the dash that shuts down..?
    If it's the Dash, then as Big Sig says, it'll be a CIM module fault which will be around £400 to fix ( if you bought from a trader then thats their problem)..
    if it's the engine, it will have stored a code as to why it's failing.. does it rev fine?.. does it do it if you stay in 1st for longer and change up later, say around 3000 rpm?..
    Berinsfield,Oxford
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    does'nt matter how long i hold first gear, generally as soon as the clutch is dipped it will cutout, the engine dies and the dash goes out.
    sorry to be vague but cannot explain it well.
    bought it from Vauxhall dealer in york(200 miles away) so will arrange for local dealer to investigate.
    If the CIm module goes down will it cause the engine to die or does this just control the dash display??
    the CIM runs all the column control's/dashboard etc..it MAY cause the cutting out..BUT if the CIM is faulty it will flag a 'non communication' faultcode..
  1. 1.9 150 cutting out
    By japkadett in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 21:26
  2. Cutting out
    By Chuddy in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 22:37
  3. my car kept cutting out??
    By Curly7 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2009, 21:23
  4. 2.2 dti cutting out in 4th and 5th
    By j brown in forum Engine & Drivetrain
    Last Post: 12th May 2008, 20:34
  5. Cutting out!
    By Mike 3.2 GSI in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2005, 13:04
