Thread: Facelift bumper removal
    york
    Eek Facelift bumper removal
    can anybody help me with a how to on how to remove my front bumper ?
    Regular Member mushy2007's Avatar
    Liverpool
    Two screws in each whell arch and then a series of screws under car by the sump etc. should just pull forward with ease and paitiece.
    york
    after hittng the fox it has left a gap in the bottom part where fog surrounds go its about two inch wide whats best way to bodge gap until i get new bumper
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    two torx screw in each side of the wheel arches and then under the car of the bumper there will 5 plastic plugs pull out the centre pin then the outer part will just pull out, then open the bonnet and you will see 2 black plastic gromets push the center pin through but put your hand under neath them as you will loose them, the pull the bumper out from the wings first (they will be like a snap fit)then the bumper will just slide forward hope this helps you out m8
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    I thought there was more to it on a facelift - obviously not!
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    It's exactly like has been said apart from 4 screws on the top part of the grille, (1 by each headlight and 2 on the top by the slam panel.)
    Coventry
    Hi,has anyone got any decent photos of these locations as I'm replacing my n/side front wing soon.
    Cheers....
    Forgot to ask, do I need to remove wheel arch plastic inserts to get to bumper torn screws?
    11 Post(s)
    Quote Originally Posted by glynn View Post
    then pull the bumper out from the wings first (they will be like a snap fit)
    Not if you do the job properly. Slacken off the upper of the 2 screws in the wheel arch, then push it back in before totally removing it. This releases the locking clips that hold the bumper to the wing so it detaches easily and no need to "snap" the bumper from the wing.
    11 Post(s)
    Quote Originally Posted by stopi View Post
    Info on bumper removal is in the how2 section
    http://www.vectra-c.com/forum/showth...84#post1277584
    Coventry
    Big Dave, your a StAr!!!
    Thx m8.
  1. Facelift rear bumper removal Urgent.
    Last Post: 27th January 2010, 20:41
  2. Facelift Front Bumper Removal
    By Gogs67 in forum Bodywork & Interior
    Last Post: 8th October 2009, 17:32
  3. Front bumper removal......pre facelift
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 22:49
  4. facelift rear bumper removal
    By skidmark in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2009, 12:20
  5. Facelift bumper removal?
    By masonic in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2007, 10:36
vectra c front bumper removal
how to remove Vectra C front bumper
removing front bumper vectra c
vectra c bumper removal
vectra c facelift bumper removal
2008VAUXHALL VECTRA C HEAD LIGHT REMOVAL
replacing vectra front wing
vectra c rear bumper removal
how to take bumper off vectra c
Vectra facelift wing bumper clips
vauxhall insignia bumper removal
how to remove bumper on 2008 vauxhall vectra
how to remove vectra c rear bumper
vectra 2008 bonnet removal
vectra front wing removal
vectors c bumper removal
vectra 07 bumper removal
