Thread: Brake Disc Size...
    Regular Member sophos9's Avatar
    Norfolk
    Default Brake Disc Size...
    Hi, got a 2003 2.2 Irmscher Vectra - MOT failure on front discs. EPC suggests 2 differing disc sizes (284mm and 302mm)
    Can you advise which ones I should order (away from car so cannot do a physical, need to order ASAP)
    Also, I presume that I should change pads too?
    Thanks in advance!
    If they are standard discs then they are deffo 284mm matey only the Turbo and early 3.2's had 302 mm
    Norfolk
    Awesome, thanks for the heads up!
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    I would suggest changing pads as well. If the discs are damaged or grooved the pads will be also, therefore when fitted with new discs you will not have a nice flate surface on the pads to match the discs.
    HTH
    3.2 v6 Signum and loving it
  1. Brake Disc Size
    By hodge725 in forum Suspension, Wheels & Brakes
    Last Post: 2nd November 2012, 17:41
  2. Standard brake disc size!?
    By rockafella8587 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2012, 19:33
  3. signum 2.2 direct brake disc size
    By jeffire in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 00:04
  4. Brake Disc Size (Apologies...)
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2010, 17:40
  5. Brake disc size?
    By joe2187 in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2009, 21:22
