Originally Posted by
a18nmk
Car is an '04 Vectra C, V6 3.0 CDTI (Estate)
Any insight into the following would be greatly appreciated:
Problem No.1:
Squealing noise (similar noise to a fan belt) coming from the engine bay, problem being that the pitch of the noise doesnt vary with rpm and only occurs up to approx 30mph. I am thinking it may be the power steering belt but not too sure.
SORTED: Dust Cover Plate rubbing against rear of brake disc. Fix - Bend back with screwdriver
Problem No.2:
Crunching noise coming from front suspension when going over speed bumps/bumpy roads etc. etc. Noise seems to dissappear once the car is "warmed up" after approx 20 miles.
SORTED: Broken rear springs. Fix - 2off new OEM springs
Problem No.3:
Diagnostic check showed a problem with "Glow Plug Relay Circuit B". Car starts fine even on the coldest of mornings no probs. How/Where do I locate this relay and do I need to replace it, or is there another, more simple fix
WIP
As I say, any ideas on the above would be greatly appreciated.
Cheers guys
Al
