Results 1 to 10 of 17
Thread: Aftermarket Sterio Fitting
    Jan 2006
    Dalriada
    Default Aftermarket Sterio Fitting
    Hello
    I have just bought myself a kenwood sterio KDC-W6527SE, ipod interphase and connectors for the steering wheel to allow the conrtols to work.
    Is their any way i can get the sterio working in a way that will allow the screen on the dashboard to work?? some other kind of lead??
    Does anyone know where i can get a lead to go from my ipod to the sterio aux??
    I am a novice at this stuff as you prob can tell so any help will be appreciated.
    Steven
    SCOTLAND
    There is an interface adaptor i think leave it with me i came across it with vectra 2.0t (paul) help when i was looking at kenwoods.
    Regular Member Robward27's Avatar
    Witham
    Autoleads do an interface which allows you to use both steering wheel controls and on screen display.
    http://www.edworthys.co.uk/product~prodID~18165.asp
    Jan 2006
    Dalriada
    cheers for the quick replys lads.
    i have bought the kenwood interface KCA-iP500 is this suitable??
    Witham
    http://www.justkenwood.co.uk/install...del.asp?id=288
    this shows what headunits are compatible with vectra can-bus system bear with us just trying to find out other info on display
    Jan 2006
    Dalriada
    cheers rob.
    I have also bought autoleads PC99-X06 multistalk adaptor and autoleads PC99-KEN multistalk adaptor patch lead.
    Any ideas what else i will need, or if this stuff will even do??
    Jan 2006
    Dalriada
    B0ll0cks looks like i have bought the wrong lead from halfrauds the PC99-X06 is for vectras upto 02. I can take them both back if thay arent compatible..as i say im a complete novice..
    Witham
    http://www.justkenwood.co.uk/stock01/kcaip500.asp thats your ipod interface what you may have to get is an adapter to allow more than one kenwood din plug this is on following site:-
    http://www.justkenwood.co.uk/stock01/kcas210a.asp
    Hope this helps you may have to get another kenwood changer cable to go from headunit to switching unit. This all depends on weather the wiring harness adaptor incorperates the din plug as there is no picture, your best bet is to email kenwood direct on site above and they should tell you exactly what you need fella.
    Jan 2006
    Dalriada
    so my interface isnt the right 1 for the job then??
    Jan 2006
    Dalriada
    ok cheers for the help rob very much appreciated
  1. Aftermarket stereo fitting
    By datcat101 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 22:22
  2. fitting an aftermarket stereo checklist please
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2011, 10:17
  3. fitting aftermarket reversing sensors
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2011, 21:57
  4. Fed up - please help... Aftermarket double din headunit fitting
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2010, 19:42
  5. Aftermarket Stereo CD Fitting
    By jrpatten in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2009, 20:12
