I have had problems with springs recently and have finally been sent a set of Eibachs. Could someone check the part number to make sure they are right for my 07 1.9CDTi.
10-65-007-02-22 (Sent direct from Eibach)
Can you check your vin plate on the side of the drivers door pillar.
This part number is for car's with Front axle weight of 1130kg and rear 980kg. It's shown as 1-XXXXkg 2-XXXXkg.
I just bought 10-65-011-02-22 and i thought it should be the same for your motor.
I'm getting info from here. http://www.roadrunnermotorsport.co.uk/index.asp
1-1090
2-0985
If these are the wrong ones I am going to flip as this is the 3rd set they have sent out.......................... ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Roadrunner and the Eibach website have 2 different sets both include the 1.9CDTi..........which ones should I have???????
Vectra C 1.8, 2.0 Turbo, 2.2, 3.2, 1.9 CDTi, 2.2 Dti 04.02 - 1060 kg 980 kg 10-65-007-01-22 £138.00
Vectra C 2.0 Turbo, 3.2, 1.9 CDTi, 2.0 DTi, 2.2 DTi 04.02 - 1130 kg 980 kg 10-65-007-02-22 £138.00
Any help please as I know a lot of you have Eibachs
These look ok then for your weights. 1090kg is just a little over the weight they quote. So possibly it will sit a tiny bit lower. But much better than 1130kg these on the car will sit high at the front.
Sorry just thought on. The one's i have are the same for the veccy bus 1.9 so i was wrong in my first post.
it wouldn't matter which ones you have in all honesty, if I had to guess one set I would say the first one? closest to the 1090 and 0985 you posted?
O sorry yes.
Well my car has 1-1120 on the vin plate. I spoke to Roadrunner and they even phoned Eibach while i waited on the phone and they said i should have the 02-22 set.
I think you should have the 01-22 set.
I'd phone Eibach direct and check with them.
Eibach website states the set I have been set are for:
Vectra C 2.0 Turbo, 3.2, 1.9 CDTi, 2.0 DTi, 2.2 DTi 04.02 - 1130 kg 1035 kg 10-65-007-02-22 £138.00
and my car is 1-1090 2-0985
Any Eibach experts out there to help before I phone AGAIN and kick off tomorrow.
