Thread: 2.0 DTI turbo problem
    Kent
    Default 2.0 DTI turbo problem
    Hi there, i have a 2.0 DTI veccy and most of the time it appears the the turbo isnt working and sometimes it does. I noticed the other day that the engine does smoke a little wen i put my foot down. Any suggestions?cheers
    get the boost pressure sensor checked out..if it's giving bad readings then the turbo won't boost.. also check for any pinholes in the boost pipes or cracks in the rubber connectors of the small vacumn lines..
    Nr Cardiff
    Boost hose split possibly?
    Does it make a loud "whooshing" noise when you boot it?
    Regular Member eaglepva's Avatar
    Up North
    Check the rubber connectors on the vacume lines mine was running like the turbo had gone but it was the little rubber connector had cracked.
    Kent
    Thanks guys, i shall check out the hoses. No 'whoosing noise' it does makes a very slight whistling sound at around about 2000 ish revs. To check the pressure sensor does it just need to be connected to a diagnostic machine? cheers
    Regular Member Matty H's Avatar
    Bristol
    Quote Originally Posted by Vibez_Uk View Post
    That IS the turbo working. You can hear it whistling at around 2k revs quite clearly. Sounds like it's working ok to me
    Nicking Ya Dinner.
    Could be the air meter also, this loses all the power if it goes faulty.
  1. 2.2 dti Turbo problem
    By Shortland78 in forum Engine & Drivetrain
    Last Post: 18th February 2011, 14:34
  2. 2.0 Turbo problem
    By the stig in forum Engine & Drivetrain
    Last Post: 4th March 2010, 20:31
  3. Turbo Problem
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2009, 21:01
  4. problem with turbo or ?
    By chikenbud in forum Engine & Drivetrain
    Last Post: 1st February 2009, 16:03
  5. Turbo Problem...
    By dankidd in forum Engine & Drivetrain
    Last Post: 11th August 2008, 22:55
vectra dti turbo problem
