Results 1 to 10 of 15
Thread: Which lowering Springs / Will a 30mm Drop affect ride quality much?
    Lisburn, N.Ireland
    Default Which lowering Springs / Will a 30mm Drop affect ride quality much?
    Sorta been looking at springs and think i'm going to order a set of 30mm Eibachs at £155 (unless you's can find me something cheaper also with abit of quality ie NOT Jamex). From previous experience eibachs have always been great.
    Also will a 30mm drop make the ride much harsher? Its an 06 Sri Cdti on the standard 17" rims.
    All replies appreciated
    Rik
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    I'm running eibach springs, 30 ish mm drop. Got mine from 888 engineering £140 ish specially altered spring rates seemingly. Car sit far more evenl. Fantastic addition. No comfort lost at all. The car sit much firmer through the corners body roll is almost gone! Will upgrade to bilstein shocks when the standard ones wear. Remember to get the steering geometry checked once you've fitted them or it will be all over the place!!!
    ^^^ what he said.. the ride is a 'little' bit firmer, but the handling is worlds apart...
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Lisburn, N.Ireland
    Excellent, cheers for the feedback guys
    Would I be asking to much for someone to post up a pic of an Sri lowered 30mm on the standard rims ?
    not standard rims, but 18's... but thats what -30 eibachs do to the ride height..
    Regular Member Dodger's Avatar
    West Midlands
    I'm thinking of lowering my 1.9 CDTi (150) Design by 30mm and fitting B6 shocks on the rear, I notice you have a tow bar fitted and wondered if there were any issues towing. TIA
    Kent
    just been to pick up my 18 snowflakes, fitted them straight away look a little lost in the arches so i to will be looking at lowering.
    btw they are running on 225/40/18 is this a recommended tyre size for 18's snowflakes
    cheers guys
    Sunny Dartmoor
    Quote Originally Posted by pords View Post
    cheers guys
    Very nice pords,where's the piccies then..... and yes thats what i have on my 18's........
    Belfast
    Really with the Vectra, upgrading the rubbish standard shockers is the first thing you should do to improve handling - especially if you're already running the SRi lowered suspension.
  1. lowering springs 30mm or 35mm cant decide
    By davedave in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2013, 06:02
  2. Replies: 0
    Last Post: 2nd December 2010, 00:30
  3. New Spring -30mm or new shocks and springs -30mm
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 12:51
  4. Eibach 30mm Lowering Springs
    By BigMan in forum Parts for sale
    Last Post: 30th September 2007, 20:32
