Results 1 to 10 of 27
Thread: speeding, have I been caught?
    Regular Member wardy's Avatar
    Chichester
    Default speeding, have I been caught?
    Was travelling along a dual carriage way the other evening in what I assume to be a 70 limit (not a built up area). Before I realised I'd passed under what looked like a SPECS camera (the type that measure your average speed from point a to b.
    Thing is I was doing about 85 when i spotted it.
    Does this camera also record your actual speed as you pass it, or just your average?
    About 1/4 mile up the road were some road works and a 50mph limit. I then passed about 4 of these cameras, but I made sure I was under 50!
    Don't understand why the first camera would be outside the 50 restriction. It was as if the road works had moved up the road, but the cameras hadn't been? My average speed between the first & second camera would be over 50 as part of it was outside the road works.
    Guess I'll just have to wait & see.
    Jul 2006
    Don't know for definite, but I would imagine that they would disable the first camera, the one before the roadworks, then set the rest to 50mph.
    Hopefully one of our BiB will be along with an answer soon....
    Regular Member glencol's Avatar
    derby
    Quote Originally Posted by wardy View Post
    its the one that records average speed,i used to go through notts to lincoln and there there and you would see people who knew they would only pass pne really belting under them then turning off. so i presume from that its the average.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    It is just the average speed.
    I regularly travel on the A77 from Kilmarnock southbound and that stretch of road is reported to have more average speed cameras than anywhere else in Britain. They definately only record average speeds because I have never been done yet. My job entails stopping at various points along the route with deliveries, which must be the reason for me not having a summons.
    3.2 v6 Signum and loving it
    Regular Member B19CBB's Avatar
    Nov 2007
    North East
    Vehicle : Insignia
    Trim : Sri Nav VxLine
    Engine : 2.0 CDTI 160 ps
    Year : 2011
    check at safespeedforlife.co.uk they will tell you exactly where the cameras are and what speed and how they record it
    Chichester
    thanks guys.
    Fingers crossed.
    Must say I did nearly 600 miles in 36 hours, and the vec came into its own. Supurb cruiser! and with the V6 CDTI I averaged 41.5mpg with most of the mileage covered at, well I won't say!
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Are you sure it was a SPECS camera?
    It is likely they are using SPECS in the roadworks, but is possible that as you only saw one camera it was NOT a camera but a trafficmaster type device. There are loads of different types of traffic montors about, green, blue, red black. Speed enforcement cams are usually yellow, or have a yellow backing so they stand out.
    Either way as has been said SPECS work on average speed, not an instant speed reading.
    SPECS use number plate recognition. Camera reads you reg plate and when you pass the next SPECS camera it reads your reg again, and then knows the time it has taken you to pass between the two points and your average speed. Time over distance = speed.
    Jul 2006
    Is it true if you change lanes between cameras they can't keep track?
    Regular Member Karl's Avatar
    Sunderland
    Apparently yes
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Quote Originally Posted by parapaul View Post
    Beautiful design flaw if its true!
  1. Caught Speeding
    By spennny in forum General Chat
    Last Post: 16th December 2009, 17:57
  2. I think I just got caught speeding!!!
    By mucklestone in forum General Chat
    Last Post: 20th August 2009, 10:29
  3. ive been caught speeding
    By mat osborn in forum The 'Off Topic' room
    Last Post: 22nd October 2008, 23:40
  4. Caught Speeding (again)
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2008, 16:49
  5. got caught speeding
    By Andy in forum General Chat
    Last Post: 22nd June 2005, 22:14
