Results 1 to 3 of 3
Thread: Rear driving light
    May 2007
    Sussex
    Default Rear driving light
    Hello all sparkies, i've had a problem with one of the right rear driving lights for weeks and can't find the cause. The bulb is fine and works on the other side of the car and according to my multimeter 12v is getting to the bulb holder. Yet it doesn't work and i get the car telling me it doesn't every time i switch the engine on.
    It happened about the time i installed a reverse parking sensor hooked up to the reverse light and earth on that side of the car.
    Would appreciate any suggestions please.
    Jul 2006
    Sounds like you've somehow created a short circuit. The bulb failure warning system measures resistance, so even if the bulb's working fine, if there's a bare wire or something that could do it.
    Just a thought - is the earth you spliced into a common earth for the whole cluster? If so, see if you can find a different earth point. I'd go back and look carefully at the work you did, just make sure everything's exactly right.
    HTH
    May 2007
    Sussex
    Thanks for the tips. if my other half hasn't pranged it again i'll have check around when she gets home.
  1. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  2. Brake light - driving me mad
    By Tony2412 in forum Suspension, Wheels & Brakes
    Last Post: 25th March 2012, 14:28
  3. Sometimes ESP light turns on while driving
    By msqualo in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2012, 22:27
  4. Blue light driving.
    By peter-gsi in forum The 'Off Topic' room
    Last Post: 4th January 2011, 13:23
  5. Battery Light comes on after 3 minutes of Driving
    By bren in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2008, 18:08
